• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    J.Gibson
    3D Mouse Suggestion
    347 Views, 7 Replies
    12-26-2012 11:46 AM
    What brand of 3D mouse would be recommended for use with Inventor 2013?
    Jason
    Please use plain text.
    Distinguished Contributor
    Re: 3D Mouse Suggestion
    12-26-2012 12:47 PM in reply to: J.Gibson
    I have the 3Dconneciox Space Navigator and I quite like it. It's really the only 3D mouse I've heard of so this is a one sided suggestion.
    http://www.3dconnexion.com/products/spacenavigator.html
    It lets you pan/zoom/rotate all at the same time and it only took a few days to really get used to it. The basic one has two buttons which can be programmed to do various things, like zoom all.
    12-26-2012 06:33 PM in reply to: pball
    Ditto on Navigator - I have more advanced model too, but only use the two buttons anyhow.
    I prefer to change the default zoom/pan behavior.
    Active Contributor
    12-27-2012 11:25 PM in reply to: JDMather
    And within a week it becomes a "how did I ever live without this" scenario.
    blair
    12-29-2012 10:56 AM in reply to: BarryZA
    Ditto, the first day take motion sickness pills and get familar with the "Home" view icon. After that you won't be able to work with Inventor without a 3D Motion Controler and will wonder how you ever worked without one.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Valued Mentor
    12-29-2012 09:41 PM in reply to: J.Gibson
    I use the spaceball 5000 (usb) with an old driver.  Works fine, I find the ball more comfortable than the new ones, and they are cheap on ebay.
    12-30-2012 05:50 AM in reply to: stevec781
    What OS are you using?
    I have 25 of these things that I haven't been able to get to work since changing to 64-bit Win 7.  (don't think I tried older driver)
    Valued Mentor
    12-31-2012 09:31 PM in reply to: J.Gibson
    They work fine on win7 64 and winXP 64 with Inv 2010 - 2013 using driver from 3dconnexion web site.  Its a bit slow with fusion but not sure if that's just a fusion problem.  Some other posts complain about fusion being slow to rotate with newer devices as well.
