• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    3D Monitor/TV/Projector
    458 Views, 9 Replies
    10-26-2012 07:38 AM
    Hi guys is there a way of viewing your Inventor models in full 3D on a 3D TV/Monitor/Projector? Obviously with a quadro VGA Card and glasses... Is it posible and how can this be set up?
    Pieter
    Please use plain text.
    Doug_DuPont
    Re: 3D Monitor/TV/Projector
    10-26-2012 08:14 AM in reply to: Raider_007
    You might to check this out.
    You have to take your model into Showcase.
    http://labs.autodesk.com/utilities/showcase_ar
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    Ryan.Martinez
    10-26-2012 08:23 AM in reply to: Doug_DuPont
    I saw something like this at AU last year. It was a walk through of a bus and you used an xbox control to move your P.O.V. around. I don't remember the name of the software though.
    Product Design Suite 2013
    10-26-2012 08:29 AM in reply to: Raider_007
    The thing is that we have a 3D projector with glasses and when we start Inventor it sees it as a 2D image. Is there a setting or something you can set to enable the 3D vision? I am new to this so dont know where to start.
    The whole setup works well with 3D movies etc but how to convert the Inventor 3D model to be the correct source...
    *Expert Elite*
    DarrenP
    10-26-2012 08:38 AM in reply to: Raider_007
    i think you would have to use other software like showcase, 3ds max or maya
    or a 3rd party add on for inventor if there is one
    10-26-2012 09:15 AM in reply to: Raider_007
    Hi thanks for all the replies so far but it sounds like this is not done easilly. I find it hard to believe that you cannot use a 3D TV or Projector with a 3D application like Inventor.
    Ryan.Martinez
    10-26-2012 09:23 AM in reply to: Raider_007
    There are more important things that need to be fixed with inventor before AD adds features like this.
    *Expert Elite*
    DarrenP
    10-26-2012 09:33 AM in reply to: Ryan.Martinez
    if you have product design standard or higher you have access to showcase
    *Expert Elite*
    mrattray
    10-26-2012 09:42 AM in reply to: Raider_007
    Just because it's a 3D model doesn't mean it can be displayed in 3D. As similar as the two things may sound, they are actually quite different.
    Mike (not Matt) Rattray
    10-26-2012 11:55 AM in reply to: Raider_007
    I see it looks like Navisworks and Showcase has a stereoscopic output function. Anyway its a pitty Inventor doesnt support it.
    I will keep on digging and see what I find.
