Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There was an old post regarding 3d grips...but I followed that thread to no resolution.My issue is that there is no 3D grip option in my marking menu. I have the option enabled under Application Tools -> parts and have also made sure the Data Interoperabilty is loaded.
It is a shared computer and a colleague can log in under his profile and he does have the 3D Grips, so it is something user specific but I cannot seems to find the issue.
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are you following this process...
Click on a Face first and then right click?
3D grips won't appear if you are clicking on a line first.
Did you both try it on the same file?
Application Engineer - Manufacturing Solutions Division
IMAGINiT's Manufacturing Solutions Blog: http://blogs.rand.com/manufacturing/
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Does anyone actually use 3D grips?
Sometimes I see stuff that makes me think I'm too set in my ways.
Have any good videos that show usefullness?
Autodesk Inventor Certified Professional
Inventor Professional 2012 Edu 32-bit
Still waiting for -Draft option on any Rib feature. -Properties Painter.
Still wondering why Edit Form is above Edit Feature on RMB?
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please be sure to check the addin "Drag and Drop Interoperability" is loaded.
This seems to control the availability of the 3D Grips context menu item.
Hugh Henderson
Simulation QA Engineer
DLS (Simulation and Material Sciences)
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Personally, I never use them, the only arguement that I have ever entertained for them as well as the 3D Grip Snap in the Assembly is for quick concept models or quick changes without having to adjust sketches, dimensions, or parameter tables, but that is just lazy modeling IMOP.
There was a time they were part of the certification exam so I had to consult on them more, but I think they removed the question from the exam now.
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I had never used them - so I just worked around the question and found the solution my way.
Then after the exam I thought maybe I should give them a second look to help prepare my students for the exam.
So I figured it all out, did the prep session and forgot about them till now. (this was a couple of years ago)
Thought maybe there might be something new.
Hugh's response has me thinking about imported bodies into multi-body solids.
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
They don't work on imported bodies, so I wouldn't get my hopes up. I think the derive link will kill that idea.
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
JDMather wrote:Does anyone actually use 3D grips?
Yes, vendors on sales calls.
Inventor Pro 2012
Vault Pro 2012
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Good point, especially for quick changes in meetings without having to fuss to much with dimension, sketches, features on a model outside of production. This doesn't seem as useful though as Fusion since that program can work with imported solids and other cad formats and with the update coming soon the ability to direct edit multiple parts in an assembly at the same time.
Re: 3D Grips Issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I took that to mean Autodesk Resellers on sales calls - that is the only time I've seen them actually used. ![]()
