• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Pro
    jletcher
    3 issues Ipart and Help and how to
    85 Views, 8 Replies
    05-10-2012 11:19 AM
    Ok have two issues here. Just really started work in 2012 factory suite with pro. I know 2013 came out why you just loading 2012. Because there is no service pack for 2013 yet.......
    OK
    Issue 1:
       I have a ipart created in Inventor 4 I belive when I click on the table in the browser to edit in excel it does a whole lot of nothing. Then I can't do anything. It did not lock up Inventor but no longer can I do anything.
    Issue 2:
      After doing  Isue 1 if I right click the only thing that shows up is the how to so I press it and this is what I get.
    Issue 3:
     What happen to my help file? It was there the other day but now poof gone. No ilogic help
    Well we just have to see if NO HELP AVAILABLE is true..............
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Please use plain text.
    *Pro
    jletcher
    Re: 3 issues Ipart and Help and how to
    05-10-2012 11:23 AM in reply to: jletcher
    Oh and yes the file is there the place it tells me it's not there........
    And all hotfixes and SP are installed.........
    James Letcher
    *Pro
    jletcher
    05-10-2012 11:30 AM in reply to: jletcher
    Ok just made a new ipart to see if it was older released iparts and no it is on new ipart also right click table edit with excel and poof nothing.
    James Letcher
    *Pro
    jletcher
    05-10-2012 12:01 PM in reply to: jletcher
    any one come on need to do work but I can't if I can not get to excel..............
    James Letcher
    *Pro
    jletcher
    05-10-2012 12:13 PM in reply to: jletcher
    Ok I found a post with the same issue but when I go to see the fix it has a video and guess what I get a big X where the play button should be. Tells me to watch the video to fix the issue but no video..
    http://usa.autodesk.com/getdoc/id=TS14079866
     HELPPPPPPPPPPPPPPPPPPPPPPPPPP
    James Letcher
    05-10-2012 12:17 PM in reply to: jletcher
    What version of Excel?  Windows?
    Have you launched Excel by itself yet?  If Excel has never been run since it was installed, it may not launch properly from Inventor.
    *Pro
    jletcher
    05-10-2012 12:27 PM in reply to: cwhetten
    windows7
    excel 2010
    And yes this is the one thing you do before you start inventor on new machine start that excel 1st.
    But as I said found the fix just cant see the video to see it done.
    Autodesk please repost video or fix link or whatever it takes so I can watch the video I NEED TO DO SOME WORK...........
    James Letcher
    *Pro
    jletcher
    05-10-2012 01:09 PM in reply to: jletcher
    AutoDesk Hello anyone out there........
    James Letcher
    *Pro
    jletcher
    05-10-2012 01:10 PM in reply to: jletcher
    AutoDesk Hello anyone out there........ Help
    James Letcher
