• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    3-D sketch export
    117 Views, 6 Replies
    01-28-2013 06:11 AM
    Can a 3-D sketch be exported from a part file an imported or pasted into an assembly file? I see an option in the browser for 2d sketch copy but not for 3D sketch.
    Dell Precision T3500
    Windows 7 Pro
    Quad Core Intel Xeon
    6 Gb SDRam
    NVIDIA Quadro
    Product Design Suite 2012 Premium
    Please use plain text.
    Re: 3-D sketch export
    01-28-2013 06:14 AM in reply to: WILLIAMF
    Why would you ever need a 3D sketch at the assembly level?
    Simply place part file with the 3D sketch into the assembly file.
    01-28-2013 06:31 AM in reply to: JDMather
    I need to save an assembly file as iges so the 3D sketch in the part is editable for an vendor to place work points at the intersecting curves.
    When I save a copy as IGES I dont see the 3D sketch in the part even though the part  file was saved to include 3d sketch.
    Therfore I figured I could just copy and paste the 3D sketch into the IGES.
    Windows 7 Pro
    6 Gb SDRam
    NVIDIA Quadro
    01-28-2013 07:57 AM in reply to: WILLIAMF
    I just tried an experiment and it worked fine for me.
    What Options do you have set (show screen capture) on open of the IGES file?
    01-28-2013 08:05 AM in reply to: JDMather
    A simple part (IPT) to IGES is no problem.
    The issue is I have an assemblt (IAM) 2 parts. One part has the 3D sketch. When I sav a copy as IGES, then open the IGES I cant edit the 3D sketch.
    Hope that is clear. The help section says it can be done.
    Windows 7 Pro
    6 Gb SDRam
    NVIDIA Quadro
    01-28-2013 08:15 AM in reply to: WILLIAMF
    Here is the import dialouge window for iges
    Windows 7 Pro
    6 Gb SDRam
    NVIDIA Quadro
    01-28-2013 08:42 AM in reply to: WILLIAMF
    Thats odd.
    If I start a new IPT and derive the IAM and save, then save copy as IGES and open it the 3D sketch is shows up and is editable. I dont think I need that extra step though.
    Is has to do with the IGES option on open.
    Windows 7 Pro
    6 Gb SDRam
    NVIDIA Quadro
