• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    2013 Graphics Issues
    1594 Views, 17 Replies
    11-02-2012 11:56 AM
    I have one PC in our office with some graphics issues.  In a new IDW when the user adds a dimension, then zooms out, all the views disappear except for the active view.  The file were using is one part and two views on the IDW so it's not a large assembly or anything complicated.  I've installed the latest driver from NVIDIA and changed the Inventor hardware settings from Performance to Compatability and back and forth which helps temporarily but then it goes back to the same issue after a while. I've maximize RAM utilzation and the problem isn't being seen in any other applications and we have the latest service pack 1.1 installed. Any suggestions?? Am I missing something?
    The configuration is:
    Dell Precision 3500
    Win 7, 64
    12g RAM
    Quad core
    Nvidia Quadro 2000
    Thanks!
    Please use plain text.
    Valued Mentor
    japike
    Re: 2013 Graphics Issues
    11-02-2012 12:02 PM in reply to: Brendabr12345
    Is it just the one drawing that has this issue?
    Have you tried the drawing on another PC?
    Can you post the part and drawing?
    Peace,
    Jeff
    Inventor 2013
    Distinguished Contributor
    11-02-2012 12:07 PM in reply to: japike
    Myself and coworker have actually had an issue like this. Sometimes when dimensioning all the views would disappear and if we would zoom in or out the views would reappear. This has happened on more than a few drawings, though I couldn't locate any off the top of head or upload them due to confidentiality.
    11-02-2012 12:44 PM in reply to: japike
    This is happening on multiple files on the same PC, files function fine on other PC's.
    *Expert Elite*
    11-02-2012 01:20 PM in reply to: Brendabr12345
    update the graphics card driver.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    11-02-2012 01:42 PM in reply to: mcgyvr
    I've actually upgraded the video card driver straight from the NVIDIA site with temporary improvement.  I'm wondering if there is a setting under the NVIDIA control that I need to modify specifically for Inventor.  The issue appears to occur on one of the dual monitors that has the digital connection.  Perhaps these issues are related, but when I move Inventor to this monitor, then close and re-open Inventor it automatically opens on the base monitor.  Could this be an indication of something related?
    *Expert Elite*
    blair
    11-02-2012 08:26 PM in reply to: Brendabr12345
    See if Windows "Aero" is enabled on this machine. A post a short while back with a graphics problem fixed it by enabling "Aero".
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Active Member
    12-14-2012 06:24 AM in reply to: blair
    Me and my employees are having the same issue as Brendabr12345. We just upgraded to Inventor 2013, installed SP1.1, & updated our graphics card drivers. I verified we are running a theme with "Aero". And when I uncheck "Enable transparency", the disappearing act occurs with half the frequency. I attached the drawing. Here is our setup:
    Dell T3500
    Windows 7 Pro
    NVidia Quadro 2000
    6 GB RAM
    Any other ideas?
    Best regards,
    Ryan
    *Expert Elite*
    blair
    12-14-2012 08:35 AM in reply to: Brendabr12345
    The IDW without the related files is useless. A screen capture would probably suffice to show the problem.
    Win7-64
    Active Member
    12-17-2012 04:27 AM in reply to: Brendabr12345
    I found a strange fix. I changed my hardware settings in Application Options > Hardware, from performance to quality. I closed the idw, and reopened it. I was having the same issue, so I switched the hardware setting back to performance, closed the idw, then reopened the file. I worked in idw environments for 30 minutes with no issues, then deployed to my employees. Last I asked on Friday, everything was running fine.
