• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    2013 Graphics Issues
    195 Views, 1 Replies
    12-23-2012 01:06 PM
    hi all, i have been using Inventor for about 8 years now between a couple of companies, and a problem which no Autodesk dealer has ever been able to rectify has been dropouts when orientating the models. this only seems to happen when there are multiple copies of the same component or sub-assembly.
    the companies i worked for had various PC installations expanding to very hight spec'd machines, but still the problem persists.
    i now work for a new company and assisted them in specifying a CAD machine, we went through the Autodesk dealer and they recommended a CAD Workstation supplier who supplied a very good PC.
    main components....
    i7-3930K cpu
    32gig pc-3 1600MHz ram
    Nvidia Quadro 4000
    windows 7-64bit
    in nearly all aspects of modelling in Inventor this machine flies, but my model now has multiple copies of the same item (part and sub-assembly) and i am now experiencing the same issues i was having in other Companies. i have attached a couple of screen shots illustrating the problem
    i have been given a (get-by) solution from my dealer 'in application settings under Display, change the min frame rate to 1' but this just makes the model jerky and un-viewable.
    is there anyone who can help or has come across this before.
    best regards
    hughcw
    aberdeenshire
    scotland
    Please use plain text.
    Valued Contributor
    Re: 2013 Graphics Issues
    12-24-2012 01:41 AM in reply to: glackcadman
    set the minimum framerate to 0 and you should get no dropouts, you will however get a slower spinning model (it all boils down to how good your graphics card is)
    Set it at 10 to get the best framerate but at the cost of component dropout
    This isn't an error or a bug, its exactly as inventor is designed
