• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    2012 Select Other Tool
    1173 Views, 44 Replies
    05-20-2011 10:04 AM
    Hey Guys,
    Am I alone in HATING the new select other behavior?  I used to be able to scroll till what I wanted was highlighted and then left click to select.  Now I have to move the mouse over and hit the green checkmark.  Here's a suggestion.  It's a simple fix.  Put the green checkmark on the left and the drop down on the right.  Don't make me hit another target.  I am getting used to the new marking menu.  The only issue I am having is sometimes it seems that I have to left click and then right click a part to get the correct context sensitive marking menu to pop.  On my machine it also pops a little slow but that is probably a graphics card deficiency.  The marking menu seems to be pulled from the Crysis Nano Suit function selector (for any gamers out there)  I love it there and I am sure I will remember all the different menus here soon.
    Randy Martens
    Please use plain text.
    Re: 2012 Select Other Tool
    05-20-2011 10:06 AM in reply to: randym1982
    You are not alone.. And I haven't even loaded 2012. :smileyhappy:
    A while ago I posted some "Autodesk Mottos" that I can't find now but
    1 was "2 mouse clicks must be better than 1"
    and "If it ain't broke, lets change it"
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Valued Contributor
    05-20-2011 10:13 AM in reply to: mcgyvr
    Ha.  No kidding!
    ScottMoyse
    05-20-2011 10:04 PM in reply to: mcgyvr
    To be fair the original select other was rubbish in the sketch environment. Unfortunately they didn't even improve that with this version. So its worse for that reason alone. Why change something if you're not going ot make it better?
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    feame
    06-29-2011 09:54 PM in reply to: ScottMoyse
    Are there any updates at all on this? Can it be reverted back to how the other releases was which actually worked?
    Example: try and create a new sketch plane on and object behind another and offset it. With the previous versions it was highlight the area, scroll to face, click and drag and move the plane to where you want it.
    Now though, it seems you can only create a new offset workplane if there is nothing in front of it, PITA when working on assemblies. Even if you move the dialogue box over the object, the mouse button has to be released for it to select the object, by which point you can drag it now.
    Just for the heck of saying it, can I just put out there I think inventor 2011 was near bang on perfect and it was the first release I've used since 6 that was stable, reliable, and useful. In the time I've been using the new release I'm finding it slow, buggy and unstable.
    And when will the parts list / assembly tree be put on a pop up dashboard like everything else already?
    Employee
    06-29-2011 10:46 PM in reply to: randym1982
    You can set back to classic context menu by clicking Customize button, switch to Marking Menu tab, turn on check box "Use Classic Context Menu", hit OK.
    Kevin Li
    SQA Engineer, Autodesk, Inc.
    Hongyuan.Li@autodesk.com
    feame
    06-29-2011 11:00 PM in reply to: KevinLi-Autodesk
    That reverts the context menu back, but doesn't alter the 'select other' tool.
    Distinguished Contributor
    06-30-2011 04:21 AM in reply to: randym1982
    Just installed 2012 and am still getting used to the new select tool. When 3d constraining and selecting the second constraint I get a confirmation tone but the 'ok' or 'apply' buttons are not available. If possible I can orbit around and pick the same feature, not requiring the select tool, and the constraint works. This is a fresh install on a rebuilt hard drive.
    If I am not the only one, hope that this gets fixed. Very time consuming.
    Pete Beau
    IV 2012 pro
    win 7
    ScottMoyse
    06-30-2011 01:32 PM in reply to: feame
    That was a well thought out response from Autodesk! ;o) sorry couldn't resist posting that
    Cheers
    Scott Moyse
    *Pro
    06-30-2011 07:15 PM in reply to: beau-tech
    I prefer the old as well.    If it "ain't" broke, then don't screw with it.
    ____________________________________________________________
    Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert
    Autodesk Silver Manufacturing Partner
    Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
    XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
    Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
