• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    2012 Make Components glitch
    750 Views, 25 Replies
    05-12-2011 05:05 PM
    Anyone else run into this?
    Multi-body parts, using Make Components.
    1) When you click the Browse folder icon to pick an Assembly to insert into, the 'Component Properties' dialog pops up, asking if you want to create a new assembly.
    2) Whether you answer yes or no, no Browse Dialog pops up.
    3) The path is left at the default of your workspace path. You can manually type in the path and Assembly name if you know it, but no ability to browse to it. It wants to create the new assembly in the default workspace folder.
    Just checking sanity... someone else please say you've run into it. Thanks :smileyhappy:
    Win7 / 64 Ult
    IV 2012 Pro
    PS - Also happens when you choose Make Part instead of Make components.
    Todd
    Product Design Suite Ultimate 2012 / Subscription
    Win 7/64
    Dell Precision 670 / 8GB NVIDIA Quadro FX4500
    Dell Precision M90 / 4GB NVIDIA Quadro MX2500
    Please use plain text.
    Valued Contributor
    Re: 2012 Make Components glitch
    06-01-2011 10:20 AM in reply to: ToddHarris7556
    Exact same issue here on two machines.
    IV2012 on Windows 7 64 bit.
    Valued Contributor
    06-01-2011 11:01 AM in reply to: andrewdroth
    Thanks, Andrew. Was starting to think I was the only one :smileyhappy:
    Todd
    Win 7/64
    Valued Contributor
    06-01-2011 11:04 AM in reply to: ToddHarris7556
    Seems like restarting Inventor will resolve in temporarily.
    Very annoying.
    Valued Contributor
    06-16-2011 08:55 AM in reply to: ToddHarris7556
    Todd,
    Are you accessing your template files on a computer other than the one you are working on? Ex. Server?
    It seems like everyone at my work is having this issue, and I'm trying to track down what might be causing it.
    Andrew
    Valued Contributor
    06-16-2011 10:37 AM in reply to: ToddHarris7556
    No, all local file access.
    Interestingly enough.... I did it yesterday, and it seemed to work OK. Didn't really have time to investigate further, but when I do, I'll post what I find.
    Todd
    Win 7/64
    Valued Contributor
    06-16-2011 11:02 AM in reply to: ToddHarris7556
    Yeah,
    Ours seems to work when you first fire up IV, but after you've been working for a while it quits working.
    08-01-2011 07:07 AM in reply to: ToddHarris7556
    Same issue here - no dialog.  Doesn't always work after a restart, though.  We use multibodied parts to make components often, so this is going to get frustrating pretty quickly if something isn't done about it.
    Member
    08-30-2011 05:12 AM in reply to: ToddHarris7556
    After installing SP1 this error still remains...
    /Claus
    Member
    brad
    08-30-2011 06:55 AM in reply to: claus.forsell
    As a workaround, I do this:
    1. Open up my destination folder
    2. Right click any file in there
    3. Click "properties"
    4. CTL+C the location
    5. Paste it in the "Make components" dialog
    Not as friendly as browsing, but it beats manually typing it in.
