• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Peer
    11 days left - Inventor NG World Cup - December02
    46 Views, 12 Replies
    12-09-2002 01:17 AM
    Test your Inventor skills and join the 'contest'.
    # of participants so far: 3
    Feel free to participate - it's just for the fun of it.
    You will get points on the scoreboard just for trying.
    The deadline for this month's challenge is December 20th 2002.
    The December contest drawing is in Customer Files (CF), Subject:
    "Inventor_NG_World Cup_ December02" dated December 3. 2002.
    WEBBASED CF:
    http://discussion.autodesk.com/WebX?14@67.Wd6TaaEbdXF^1@.ee940b5
    NTTP CF:
    news://discussion.autodesk.com/autodesk.autocad.customer-files
    Setup note: The drawings are metric and in first angle projection.
    Follow these simple rules:
    1 - Print the 5 drawings and don't look at them.
    2 - Setup your environment (metric/first angle projection) and start a new
    sketch.
    3 - Place the drawings face down, start the clock, flip the drawings over
    and model them as fast as possible ending up with an Assembly with the
    correct weight as indicated on the Assembly drawing sheet.
    4 - Check the weights with the Accuracy setting 'Very High' of the different
    models as indicated on the corresponding drawing sheet before making the
    final Assembly.
    #1 priority: Correct weight of the Assembly with the Physical Properties
    Accuracy setting 'Very High'.
    #2 priority: Fastest time.
    Let me know how fast you can model and assemble it (don't cheat - it's no
    satisfaction to
    be the fastest when you know you've cheated).
    Email your resulting time directly to me (to keep it a secret) along with
    your comments (ph@ambu.com).
    If you are dead sure you've made it right and you don't get the correct
    weight(s) using the Physical properties 'Very High' Accuracy, I would be
    very interested in checking your model(s).
    NOTE: Please follow these guidelines before posting files to me directly:
    1 - Pull the End of Part marker up below the Origin folder in the Browser
    tree on all the models.
    2 - Pack and Go the Assembly file and related models.
    3 - Use Winzip (www.winzip.com) to compact the files.
    The winner will be contacted directly for uploading the model and additional
    comments.
    I'll report back to the Inventor 6 NG with the results and an updated
    scoreboard when the 'contest' is over.
    See the recent scoreboard for this contest in CF, subject:
    "INVENTOR NG WORLD CUP - NOVEMBER 2002 - MODELS" dated November 21. 2002.
    Enjoy,
    Peer
    Please use plain text.
    *Yeandle, Laurence
    Re: 11 days left - Inventor NG World Cup - December02
    12-09-2002 06:21 AM in reply to: *Peer
    You can normally tell the difficulty level by number of participants so far
    or there are a lot of chickens masquerading as design engineers using IV put
    off by five drawings :smileyhappy: Guess which group I'm in.
    Laurence,
    Power is nothing without Control
    "Peer@Home" wrote in message
    news:F0860C00E432B538FE3C5E132A62BA17@in.WebX.maYIadrTaRb...
    > WEBBASED CF:
    > NTTP CF:
    > sketch.
    different
    > final Assembly.
    > satisfaction to
    additional
    > comments.
    > Enjoy,
    > Peer
    Distinguished Contributor
    Re:
    12-09-2002 06:34 AM in reply to: *Peer
    Now, now be nice :-)
    I know I'm counted so far.
    Regards
    Steve
    *Dotson, Sean
    Re:
    12-09-2002 07:14 AM in reply to: *Peer
    I'm psyching myself up
    Sean Dotson, PE
    http://www.sdotson.com
    Check the Inventor FAQ for most common questions
    www.sdotson.com/faq.html
    "Laurence Yeandle" wrote in message
    news:smileyvery-happy:0BBB79F7A673814B8D56389CFE3DBCB@in.WebX.maYIadrTaRb...
    far
    put
    > Laurence,
    > > WEBBASED CF:
    > > NTTP CF:
    new
    > > sketch.
    over
    > different
    > > final Assembly.
    no
    > > satisfaction to
    with
    directly:
    Browser
    > additional
    > > comments.
    2002.
    > > Enjoy,
    > > Peer
    Re:
    12-09-2002 08:51 AM in reply to: *Peer
    How could you need to psych your self up? You wouldn't have seen the drawing yet (according to the rules)
    Regards
    Steve
    *Dotson, Sean
    Re:
    12-09-2002 10:14 AM in reply to: *Peer
    From what I've heard about it.  (see Peer
    Hoffmann is a machocist thread)
    How
    (according to the rules) <VBG>
    Regards
    Steve
    *Bliss, Charles
    Re:
    12-09-2002 10:52 AM in reply to: *Peer
    Being home today, I decided to take in on. After several mis-starts (it
    helps to read the directions) I got it done. Peer is a masochist with
    holiday spirit. I don't recommend doing it on anything less that a 1
    Gigahertz computer.
    Sean Dotson wrote:
    > From what I've heard about it. (see Peer Hoffmann is a machocist thread)
    > Sean Dotson, PE
    > www.sdotson.com/faq.html <>
    > "sstrik" > > wrote in message
    > news:f12af5e.3@WebX.maYIadrTaRb...
    > Regards
    > Steve
    *Vlaming, Cor J. de
    Re:
    12-09-2002 02:29 PM in reply to: *Peer
    I allready told Peer this thing is (edited) to make I made it and it took me
    5.5 hours
    Little hint
    make a acis body and scale it in MDT. and take over the project geometrie
    greetings Cor
    Re:
    12-09-2002 03:22 PM in reply to: *Peer
    Looks like I'm in the lead then :smileyhappy: No need to do the export thing, just keep the 1st sketch visible when you create the other parts. You can then just select the dimensions already created.
    regards
    Steve
    ps It was a bugger of a thing to do though.
    *Hoffmann, Peer
    Re:
    12-09-2002 10:50 PM in reply to: *Peer
    Steve - if you want to stay in the lead (I didn't say you were) don't give
    any hints...8^)
    And a piece of advise to all: this is an Inventor challenge, no need to
    involve MDT.
    It'll only come out with the wrong weight...I'm told.
    BR
    Peer
    "sstrik" wrote in message
    news:f12af5e.7@WebX.maYIadrTaRb...
    regards
    Steve
