• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Publisher
    Active Member
    Accepted Solution
    trial version has no help
    298 Views, 2 Replies
    06-04-2012 08:11 AM
    When I click Help in the trial version, it takes me to a site that says "access forbidden".
    I'm trying to put together a good demo to convince my company to buy the software, but it's not easy without proper access to the Help system.
    Is there a way to make the online Help work in the trial version?
    Please use plain text.
    Employee
    Re: trial version has no help
    06-04-2012 08:25 AM in reply to: kickseek
    The help should be accessible in the trial version.
    Here is a direct link to the help.
    http://wikihelp.autodesk.com/Inventor_Publisher/ENU/2013
    Rajkumar
    Active Member
    06-04-2012 08:42 AM in reply to: kumarra
    Thanks!
    Your link works, but the Help button in the trial version does not.
    The following error message is sent by your web server:
    Forbidden
    You don't have permission to access /Inventor_Publisher/ENU/2013 on this server.
    Apache/2.2.3 (CentOS) Server at wikihelp-stg.autodesk.com Port 80
