Autodesk Inventor Publisher
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
rotation around center of hole.
- Highlight
- Email to a Friend
Hi, im trying to set up an animation of a torque wrench tightening a bolt.
problem is i cannot find out how to set the rotation axis accuratly at the centerline of the bolt (or any central axis that is not a physical line)
Re: rotation around center of hole.
- Highlight
- Email to a Friend
Click the bolt
Click the Move component
Holding Ctrl, select the wrench (if it's more than one part, use the canvas)
Rotate away!
- Highlight
- Email to a Friend
Thank you, this solved my broblem,
but i am curious if there would be a solution to this if there were noe bolt to rotate around? is there no way to set rotation axis around the centerline of a hole?
- Highlight
- Email to a Friend
If you select an object with a hole, say a nut, the Move component will automatically align to the centre of the nut.
Don't forget, you can chose any object on your model to align your axis to.
