• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    OTH
    New Member
    Accepted Solution
    rotation around center of hole.
    464 Views, 3 Replies
    02-14-2013 02:57 AM
    Hi, im trying to set up an animation of a torque wrench tightening a bolt.
    problem is i cannot find out how to set the rotation axis accuratly at the centerline of the bolt (or any central axis that is not a physical line)
    Please use plain text.
    Distinguished Contributor
    bowen192
    Re: rotation around center of hole.
    02-15-2013 07:21 AM in reply to: OTH
    Click the bolt
    Click the Move component
    Holding Ctrl, select the wrench (if it's more than one part, use the canvas)
    Rotate away!
    OTH
    New Member
    02-19-2013 01:48 AM in reply to: bowen192
    Thank you, this solved my broblem,
    but i am curious if there would be a solution to this if there were noe bolt to rotate around? is there no way to set rotation axis around the centerline of a hole?
    bowen192
    02-19-2013 04:38 AM in reply to: OTH
    If you select an object with a hole, say a nut, the Move component will automatically align to the centre of the nut.
    Don't forget, you can chose any object on your model to align your axis to.
