• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Publisher
    Active Member
    jeff_connelly
    iOS5 problem
    160 Views, 9 Replies
    10-14-2011 06:59 AM
    Content is listed on the left hand side of the viewer but when clicked, nothing happens.
    Please use plain text.
    Employee
    Re: iOS5 problem
    10-14-2011 07:27 AM in reply to: jeff_connelly
    Hello Jeff,
    I assume you are seeing this on the iPad? If so can you please specify if it is the iPad or the iPad2?
    -Raj (Autodesk)
    Active Member
    jeff_connelly
    Re: iOS5 problem
    10-14-2011 07:31 AM in reply to: rajkumar.ilanchelian
    Yes.  I am running iOS5 on an iPad 2.  An associate is also having the same issue with the same content on an iPad 1.  I also run iOS5 on an iPod Touch but the content works there.
    I'm currently trying to delete and re-add the content on the iPad2.
    Employee
    Re: iOS5 problem
    10-14-2011 07:55 AM in reply to: jeff_connelly
    Thanks for the information. We will look in to this issue.
    -Raj (Autodesk)
    Employee
    Re: iOS5 problem
    10-14-2011 08:18 AM in reply to: rajkumar.ilanchelian
    Jeff,
    From my limited testing I notice that the "sample content" files found in the models tab is the ones that are not showing up. Files that I have published to the Autodesk server is displaying correctly. Is this true in your case as well? Are you able to view the files that you have published to mobile?
    -Raj (Autodesk)
    Active Member
    jeff_connelly
    Re: iOS5 problem
    10-14-2011 08:28 AM in reply to: rajkumar.ilanchelian
    I don't have anything published to the server.  I can view the models in the "Gallery" but not the models I add through iTunes into the app's "Models" fiolder.
    I tried deleting the models from the iPad and re-add them through iTunes and then sync.  This results in nothing showing up in the app "Models" folder.  I even restarted the app each time I tried something new.  Meaning I double click the home button and remove the app from memory.  I also tried a soft reset on the iPad 2.
    As it sits now, I have no content loading to the app even though iTunes shows the content in the Add window.  I can view the Gallery models.  I have no published content but will try that next.
    One last thing, I've been syncing tethered to a Macbook Pro.  Not using the wireless sync.
    Employee
    Re: iOS5 problem
    10-14-2011 08:52 AM in reply to: jeff_connelly
    Thanks again for the details. I take it that this was working for you prior to iOS 5 updates correct?
    -Raj (Autodesk)
    Active Member
    jeff_connelly
    Re: iOS5 problem
    10-14-2011 09:45 AM in reply to: rajkumar.ilanchelian
    Yes.  Everything worked before but now the iPad 1 and 2 do not work.  iPod touch still works even with iOS5.
    Active Member
    jeff_connelly
    Re: iOS5 problem
    10-14-2011 10:56 AM in reply to: jeff_connelly
    New iPhone4S running iOS5 works.
    Active Member
    jeff_connelly
    Re: iOS5 problem
    10-14-2011 12:57 PM in reply to: jeff_connelly
    Got it working on the iPad2.
    Here's how I did it...
    On the iPad, deleted the app from the iPad.
    On the iPad, went to the Appstore and re-downloaded IPM Viewer
    In iTunes, added my models
    In iTunes, did a Sync.
    Models show up as before.
