• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    Valued Contributor
    dherman469
    Update causes storyboard problems
    75 Views, 1 Replies
    03-16-2012 12:11 PM
         I made a storyboard of an assembly file.  The inventor components originally had no material or color scheme assigned to them, so I assigned colors to the components inside Publisher.  Some minor updates were done to the Inventor assembly file, so I opened up the Publisher file and clicked the update button.  When the update was completed, all of my color assignments disappeared.  Also, I had turned off the visiblity of some components in the later slides, but the visibility of those components returned after the update.  Did I skip a step when I did the update?  There must be a way to do an update without losing assigned colors or reverting component visibility.  I have attached two pictures showing the before and after.  Can you please tell me what I'm doing wrong?  Thank you very much.
    Daniel Hermanson
    Spraying Systems Co.
    Please use plain text.
    Valued Contributor
    dherman469
    Re: Update causes storyboard problems
    03-16-2012 01:06 PM in reply to: dherman469
    I am not sure if this matters or not, but when I inserted the assembly file into Publisher, I got this warning message.  I actually forget which option I chose.  Would this have caused the color and visibility problem?
    Daniel Hermanson
