Autodesk Inventor Publisher
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Turn off Shiny Appearance
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I inserted a 3D assembly into a new Publisher document. The component parts are retaining their "Shininess" setting from Inventor. I would like to modify or turn off the shininess setting when the model is in my Publisher document. Even when I change the color of a part, the shininess stays the same. Is it possible to turn off the shininess of a part?
Daniel Hermanson
Spraying Systems Co.
Re: Turn off Shiny Appearance
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Daniel -
The "Shininess" you are seeing must be the result of the material you have applied to the part in Inventor. If you want a less shiny surface, you can change the material of any part from within Publisher. Simply changing the color will not modify the material applied, just the rgb value applied to that specific material.
To change the material of a part, right-click within the authoring environment and select "Material". This launches the Material marking menu (where you have tried to changed the color already). There is a blue square at the top of the marking menu that will drop down a list of basic materials, as well as an option to launch the Autodesk Material Library. From here you can assign any material you'd like.
Timera
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks, Timera. That works.
Daniel Hermanson
