• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Publisher
    Active Contributor
    Styles Issue
    156 Views, 4 Replies
    03-31-2011 11:05 AM
    Guys,
    I am in the middle of a very fustrating problem. I have set up a publisher document with many snap shots showing various views and details. I had set up each view with slightly differt styles. (technical line drawing, ghost, shaded, gray scale etc..).
    Now I can't change the styles back to what I had originally. I have tried everything. Can anyone help me on this?
    Thank you in advance!!
    Michael
    Please use plain text.
    Employee
    Re: Styles Issue
    03-31-2011 05:01 PM in reply to: michael.shelley
    Try this:
    • Select the root (or highest level assembly of interest) in the browser on the left.
    • In the styles command (gallery) select "Clear Style"
    That may work.  If it doesn't work, try:
    • area-selecting all the components (drag-rectangle-select)
    • Then do Clear Style
    If that doesn't work then try to select all intervening sub-assemblies (one at a time, for a start), and do Clear Style on them.
    Let us know if any of those work.  Sorry it's not easy.
    Jon Balgley
    Autodesk Inventor ETO team
    Autodesk, Inc.
    Active Contributor
    Re: Styles Issue
    04-01-2011 12:35 AM in reply to: Jon.Balgley
    Tried all of these things. And nothing!! It now looks like I have to make a new publisher document. Now I'm a little afraid of using styles. Unless you can suggest something else?
    Using publisher 2012 by the way.
    Michael
    Employee
    Re: Styles Issue
    04-01-2011 11:55 AM in reply to: michael.shelley
    Can you send me the IPB file?  Or a representative sample?
    Email to jon.balgley@autodesk.com
    Thanks, and we'll try to help!
    Jon Balgley
    Autodesk, Inc.
    Distinguished Contributor
    bowen192
    Re: Styles Issue
    04-04-2011 01:37 AM in reply to: michael.shelley
    I don't know if this helps but I had a simalar problem and found a workaround.
    I found that I could not change the style of a complete assembly if I'd already done it once already.
    My workaround is to select a single component, invert the selection and then change to the desired style.  Select the original single component and change that to the desired style.
    Hope this makes sense.
