• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Publisher
    Active Contributor
    Some things we miss badly
    702 Views, 14 Replies
    09-24-2012 05:54 AM
    I found the time this day to write down only a few hopes for 2014 and misses for 2013
    1. Update also non Autocad Inventor files.
      We love the update function but why we have this restriction that it only work with inventor files.
      We normally use DWF files from Inventor (we get this automated from SAP) and this is a big missing that the update wont work there.
      Also a update of PTC files will be a big winner inside my company cause we have both Inventor and ProE
    2. Preview of Autocad views from a Inventor DWG.
      We use the DWG format inside Inventor but we never get a preview by inserting blocks from this drawings
    3. Update of this drawings  i talked about under topic 2
    4. Supporting layers for all non 3D content like texts / pics and so on
      We have to create multilingual documentations so this will be a big time saver
    5. On publishing selectabel conting regarding to topic 4 here
    6. Enable Illustrator and QuarkExpress export
    7. Support the clipboard for pictures / DWG / DXF
    So i think this is enough for this first list.
    I hope my thoughts will help you
    Please use plain text.
    Employee
    Re: Some things we miss badly
    09-27-2012 08:42 PM in reply to: frank.schalla
    Hi Frank,
    Thanks for your feedback. I have add these wishlist to your internal issue tracking system.
    -Irene Chen
    Inventor Publisher QA
    Active Contributor
    09-27-2012 11:28 PM in reply to: irene.chen
    Hello Irene
    thank's for your feedback.
    You and the dev team can contact me when ever you like to get more detialled thoughts.
    It will be interesting what the dev team says about my ideas.
    To far away from real or a understandable customer enhancement :smileyhappy:
    Employee
    09-28-2012 09:06 PM in reply to: frank.schalla
    Thank you! Frank
    These suggestion are helpful for us to know what the real user want. I've add these as wishlist and give PD for referencence.
    -Irene Chen (Irene.chen@autodesk.com)
    Active Contributor
    10-18-2012 02:27 AM in reply to: irene.chen
    I miss some better way to align callouts, like a grid or something!
    I also would like to separete the Move and Restre Home button. i would also like to be able to insert other type of document in Publisher like word documet or PDF and be able to choose if the snapshot will be visible in the published document.
    just my wish list.
    Best regards
    Timmy
    Active Contributor
    10-18-2012 11:10 PM in reply to: timmy.stalnacke
    One more.
    be adble to choose a from templaes when creating a new .ipb
    Active Contributor
    10-24-2012 01:26 AM in reply to: timmy.stalnacke
    one more!
    be able to search and replace text in the publisher file.
    maybe even some spelling correction.
    Employee
    10-24-2012 06:35 PM in reply to: frank.schalla
    Hi Timmy,
    Thanks for your suggestion, I've added it to wishlist in the internal tracking system.
    Irene Chen
    Active Contributor
    Nice to hear!   I would also like to be able to control t...
    10-25-2012 04:47 AM in reply to: irene.chen
    Nice to hear!
    I would also like to be able to control the visible trails like i can do in a Inventor presentation.
    Member
    arjendenobel3640
    Re: Nice to hear! I would also like to be able to control t...
    11-06-2012 06:09 AM in reply to: timmy.stalnacke
    I have the same problem with trails here. I would like to make a part of a trail line invisile. See image.
    I think there is no way to do this in Publisher 2013
