• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    Active Contributor
    CadlineSupport
    Publisher 2013 Word Add-in Error
    857 Views, 25 Replies
    08-21-2012 07:53 AM
    Publisher 2013 SP2 when I click to link to an IPB file from inside Word 2010 I receive the following error: 'Exception has been thrown by the target of an invocation' Following this nothing happens (the link is not created). I have tried a repair and reinstall of Publisher with no success. Can anyone advise please? Many thanks
    Please use plain text.
    Active Contributor
    Re: Publisher 2013 Word Add-in Error
    08-21-2012 11:16 PM in reply to: CadlineSupport
    I have no solution but i have the same problem!
    If i check my Add-ins in word, can i see that the Autodesk vault addin for office 2010 is closed?
    and i cant restart it.
    //Timmy
    Active Contributor
    08-22-2012 01:06 AM in reply to: timmy.stalnacke
    I did restart the vault add-in but i still can't uppdate the word file!
    Active Contributor
    CadlineSupport
    08-22-2012 08:05 AM in reply to: timmy.stalnacke
    Hi Timmy,
    I think there may be some confusion. My post was regarding the Publisher add-in in Word, not the Vault add-in. If you have lost your Vault add in tab for Word it can be easily restored using Add or Remove Programs - go to the Vault Client,   Uninstall/Change, remove the Word add in component, and then do the same thing again and add it. This has worked fine for me every time. This is probably also documented on the Vault forum.
    Employee
    08-22-2012 07:25 PM in reply to: CadlineSupport
    Hello All,
    Thank you all for posting this issue in newsgroup. I can also reproduce the word addin issue. And this has been logged in the internal defect tracking system.
    Peggy
    Peggy Wang
    Sr. Software QA Engineer
    Publisher Quality Assurance Team
    Autodesk, Inc.
    Active Contributor
    08-23-2012 12:40 AM in reply to: peggy.wang
    Sorry!
    I tought that the update didn't work beacuse word didn't have conections to the vault.
    Active Contributor
    CadlineSupport
    08-23-2012 01:02 AM in reply to: CadlineSupport
    Hi Timmy,
    No, I was getting the Invocation error message before I pointed Word to any IPB file to link to so Vault was nothing to do with it.
    Thanks Peggy for the response. The Add-in was working with SP2 until recently, it must have been a windows update of some kind?
    New Member
    09-27-2012 07:13 AM in reply to: CadlineSupport
    I have exactly the same problem.
    Inventor Publisher 2012 plug in for Word 2010
    Trying to link or to insert a file results in the described error.
    I see the answer of Peggy Wang.
    But no solution yet?
    Employee
    09-27-2012 08:14 PM in reply to: Tamarinof
    I am sorry you met this issue and gave us the feedback. the workaround is to uninstall SP2 and back to SP1, or you also can wait for our next version.
    Irene Chen
    Inventor Publiher QA
    Active Contributor
    09-27-2012 11:06 PM in reply to: irene.chen
    Hi!
    How do I uninstall SP2?
    When will next version be relesed?
    //Timmy
