• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    New Member
    Problems with zooming in after Publish to Mobile
    637 Views, 2 Replies
    09-27-2012 03:04 PM
    I'm using Publisher 2013 to create assembly/dis-assembly instructions.  After I get the animation how I like in Publisher, I use the Publish to Mobile command in order to view it on an iPad.  On the iPad, I've noticed that when the animation zooms in on fasteners, it is sometimes too far away or too close (often ending up in the interior of some other part).  There doesn't seem to be any predictability other than the first zoom-ins tend to be as I created them in Publisher.  I'd like to know if anybody else is having this issue and/or if there is some setting that I'm overlooking.
    Joyce Takeyasu
    Please use plain text.
    Employee
    Re: Problems with zooming in after Publish to Mobile
    10-11-2012 07:02 PM in reply to: jtakeyasu
    Hi Joyce,
    Thanks for your feedback. The Publisher desktop and Viewer are based on different graphic system, each system has its own model scene, so you will see different view for the same camera. It is hard to have these two with same scene, it is the limitation.
    Irene Chen
    Inventor Publisher QA
    New Member
    10-14-2012 10:06 PM in reply to: jtakeyasu
    I got a tip from other Inventor Publisher users to create snapshots in Perspective instead of Orthogonal (right click on the View Cube to access these settings) when creating storybooks that will be published to mobile.  This has solved the unpredictable zooming issues that I was experiencing.
