• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    robert.ruhe
    Problems publishing to mobile.
    783 Views, 6 Replies
    05-17-2012 08:27 AM
    First, I have a model that simply won't publish to moble. It doesn't give me an error either. I follow the proper steps to begin the publish process - the status bar appears at the lower left corner of the application window - then disappears after a few seconds. There is no file generted at all. It simply stops without any result. I've reviewed all the help files without finding a reason why this happens.  Can anyone help me out?
    Additionally I have some models that do successfully publish to mobile but exceed the iPad 2 device capabilities. Is there anything I can do in Publisher to remedy this? Will there be fixes to the app? I am not an Inventor designer so I can't do anything to the model in Inventor itself - But I have to  find  a way to get this to work in the iPad viewer.
    Thanks in advance for your help.
    Please use plain text.
    Employee
    TimeraAutodesk
    Re: Problems publishing to mobile.
    06-06-2012 07:05 AM in reply to: robert.ruhe
    Hi Robert,
    Are you still having problems publishing a particular file to mobile? If so feel free to send the IPB to my email and I can look to see if there is something we can fix there.
    As far as your other heavy data, if you don't have access to make modifications in Inventor, you can still have some control when you Import into Publisher. At the Import dialog, there is an Options button where you can specify the faceting (smooth, course, etc). Reducing this to course can help with bloating of the cad data.
    We do understand that large assembly publishing is important to be viewed on the iPad and we are looking into solutions.
    Thanks for your post,
    Timera
    Timera.hart@Autodesk.com
    Valued Mentor
    coreyparks
    10-08-2012 11:34 AM in reply to: robert.ruhe
    Has anyone solved this issue?  I am having the same problem.  I can seem to publish files to A360 but then I can't get to them through IPM viewer.  So I tried to publish mobile localy and no file is generated at all.  The files that it is publishing to A360 are .IPB and .INRUCTION file extenisons not the IPM that it tries to export locally.  Publishing to A360 worked only once on the first attempt and I haven't been successful again  Never worked even once locally.  When trying to view online with IPM Viewer All I get is "Autodesk service could not be reached".
    Please mark this response "Accept as solution" if it answers your question.
    Corey Parks
    IV2012 Factory Design Suite Ultimate 64bit
    Includes: Inventor Professional, AutoCAD Architecture & Navisworks Manage
    Windows 7 64 bit- Synergis Adept document management software
    16gb RAM --- Nvidia Quadro 4000 2gb
    Employee
    10-11-2012 08:56 PM in reply to: coreyparks
    Did you update the Inventor Publisher view to latest version on your phone or pad? if so, could you please send me the file you met the issue, then we will do some inventigation.
    Irene Chen (irene.chen@autodesk.com)
    Inventor Publisher QA
    Valued Mentor
    coreyparks
    10-25-2012 03:00 PM in reply to: irene.chen
    Sorry never got notified of any replies to this.  Yes I have the most up to date version unless something was released after Oct 10th or so.  I can gladly send you the file if you're still interested as I still can' get this to work.
    Corey Parks
    Employee
    10-25-2012 06:47 PM in reply to: coreyparks
    Could you please give me your e-mail address, then I can send you the 'Request File" mail by system if the file is big, you can upload the file according to the steps mentioned in the mail.
    Irene Chen(Irene.chen@autodesk.com)
    Valued Mentor
    coreyparks
    01-25-2013 11:32 AM in reply to: irene.chen
    I finally figured out where the problem is coming in, for me anyway.  If I import an assembly that has a sub-assembly inside of it and then I ballon the sub-assembly so the ballon draws it's information from the parent and not any of the chirdren I can't publish to mobile.  If I balloon all of the children of that sub-assembly and not the parent assembly itself it publishes just fine.   Repeated the problem on 2 different files.
    Corey Parks
