• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Publisher
    Active Contributor
    Problems in colours
    301 Views, 13 Replies
    05-23-2012 12:54 AM
    Hi there,
    I spet my valuable time to define some colours around a system in Inventor. But when you transfer the finished assembly to Publisher you will receive different colours!!!!
    What is this about?!
    Ali
    Please use plain text.
    Employee
    TimeraAutodesk
    Re: Problems in colours
    05-24-2012 09:48 AM in reply to: jahed.ali
    Hi Ali,
    It'd be helpful if you could provide some screenshots to show what kind of differences you are seeing. Also, are you applying Materials in Inventor, or just a Style representation? And, what level are you applying this change at in Inventor (Inventor has certain overrides within itself that can be tricky)?
    Timera
    Member
    alihillaldam
    05-25-2012 05:44 AM in reply to: TimeraAutodesk
    Please see attached file.
    I used the drop down menu on the top of the Inventor screen to choose the material and color.
    Employee
    TimeraAutodesk
    05-25-2012 09:35 AM in reply to: alihillaldam
    From the image you provided, the materials look to be consistent - it's the difference in lighting environments between the two different programs that is causing the visual difference. You can change the environment in Publisher as you wish by using the Background dialog and choosing "Environment". The Grey Room setting is my personal favorite setting.
    Member
    alihillaldam
    05-27-2012 11:41 PM in reply to: TimeraAutodesk
    It is not about that.
    Draw something in Inventor open it in Publisher you will see the differences.
    You can not find them the same.
    Employee
    TimeraAutodesk
    05-30-2012 02:09 PM in reply to: alihillaldam
    The materials import, but the lightiing environments are definitely different, casting different shadows, etc. Inventor Professional on the left, Inventor Publisher on the right.
    If you're looking for a differnt matieral effect, you can use the extensive Autodesk Material Library from within Publisher to modify any material in your assembly as you desire.
    Timera
    Member
    alihillaldam
    05-30-2012 11:07 PM in reply to: jahed.ali
    Mate,
    As you saw there is a problem.
    Please make a report and forward it to top level managers. It is stupid having this. There must be a consistency between these two programs.
    Cheers
    Ali
    Distinguished Contributor
    bowen192
    06-01-2012 01:16 AM in reply to: alihillaldam
    alihillaldam wrote:
    Mate,
    Cheers
    Ali
    Agreed. This error is ridiculous. I've even had a client asking why our images are so dark now. It is nothing to do with Background > Environment. Very frustrating.
    bowen192
    06-07-2012 01:40 AM in reply to: bowen192
    Any news or progress on this?
    It is quite a big issue imo, suprised no-one else has pushed it.
    Employee
    TimeraAutodesk
    06-07-2012 07:20 AM in reply to: jahed.ali
    Thanks for your patience, guys.
    Again, this is not a colors issue, but rather a difference in the software environments that we're viewing them in. If you take any other 2 pieces of software and load the same model you will see similar differences in the way each program reflects the geometry and materials. I am waiting to hear back from one of our lead architects on a more detailed explanation for you, but will update you when I have more information.
    Timera
