• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    New Member
    Inventor doesn`t open anymore
    706 Views, 2 Replies
    04-17-2010 10:44 AM
    Hi all!
    Well, last week i`ve installed the Autodesk Inventor Publisher 2011 x64 on my pc. But I`ve had a little problem in registrating it over the internet, so I closed the inventor and restarted.
    But now, when I try to run the inventor again, appears a message error that says:
    The Application is unavailable.
    No license available. License does not exist or has expired.
    What can I do? I tried to reinstall so many times, but the problem continues. I've installed even the Network License Manager, but I don`t know how it works!
    Is there some thing to do to make the inventor to work like it was for the first time I`ve installed it on my pc?
    My operational system is Microsoft Windows Seven Home Premium.
    Please use plain text.
    Re: Inventor doesn`t open anymore
    04-19-2010 08:24 AM in reply to: rotadig
    I guess the problem you're having is because you've installed the program and the activation has failed probably due to a firewall or proxy.
    The best way to fix this would be:
    Uninstall the program completely.
    Restart the machine.
    Run the registry cleaner section of a tool similar to [CCleaner|http://bit.ly/bDicra] and remove any redundant registry entries.
    Create a backup of your registry first! CCleaner should prompt you to do this.
    Restart the machine again.
    Try and reinstall.
    Alex.
    New Member
    04-19-2010 01:18 PM in reply to: rotadig
    Well, actually i`ve already solved the problem. I did all you typed before, and no way to work.
    The solution was to restore my system in a backup made before I installed the Inventor Publisher. It worked!
    Thanks for the Reply!
    Rotadig
