• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    Member
    Accepted Solution
    How to mark an object's original position on autodesk inventor publisher?
    627 Views, 2 Replies
    09-11-2012 10:57 AM
    Hi I have created a model on autocad which I have imported into autodesk inventor publisher...for my project I have to simulate an object's assembly and subsequent dissassembly. But to begin with my model is assembled so i have exploded it and now I want to put it back together - however I can't get the program to remember the position each component was originally in so when i try and move each component back it's all over the place and looks awful. Is there a way to mark an object's intial location so that i can move it back to exactly that place?
    Any help is very much appreciated
    Please use plain text.
    Employee
    Re: How to mark an object's original position on autodesk inventor publisher?
    09-11-2012 11:00 AM in reply to: tombrownill
    Select a component and you should see the "Restore Home" command active in the ribbon. This will take the component to the initial home position. Hope this helps.
    Rajkumar
    Member
    09-11-2012 11:08 AM in reply to: kumarra
    ah great thanks man!!
