Autodesk Inventor Publisher
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How should I put out to PDF?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We've have a huge problem when we want to publish our work to PDF.
We want it to look like the picture in the zipped file, but we get the result you see in the PDF.
Anyone with great ideas here?
Re: How should I put out to PDF?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think there's a setting on text boxes that makes them automatically scale and vice-versa. Have you tried that?
Alex.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Same result. Edited by: magnus.damgren on May 20, 2010 11:55 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It seems that it simply can't cope with outputting text boxes as per the screen setup - for .pdf format at least.
Have you tried the other available formats? What results do they produce?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you publish to an 'image' format, the default size is the window size, so you end up with WYSIWYG. It doesn't work that way for PDF or Word or certain other formats.
Hope this helps.
Jon Balgley
Autodesk Inventor ETO team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The trouble is that I run two 20" monitors at 1600x1200 resolution; From what you have said this means that if I want Publisher to output usable snapshot images to my word template at 800x600 resolution that I have to change the resolution on the monitor that is running publisher to match the desired output size?
This makes no sense.
Edit: After re-reading your post Jon, it's actually worse than making the overall monitor resolution smaller; without a third party application it's almost impossible to guess the resolution of a window within an application. Edited by: vegbruiser on May 21, 2010 11:59 AM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
* As you figured out, you don't have to change the monitor size, just the window size.
* Yes, it's hard to set the size of the inside-canvas. But it doesn't need to be exactly right, either. As long as it’s “close”, then you probably won’t notice any dramatic movements of the annotations.
* You can use a larger size window (of the correct aspect ratio), if you publish at a lower DPI. For example, if your window size is 1600x1200, and you want to publish at 800x600, AND you want annotations to remain proportional (what you see is what you get -- WYSIWYG), then you can publish to a “Custom…” size (800x600) and select 36 dpi (72/(1600/800)) (where 72 is “standard” screen DPI, 1600 is the width of the window, and 800 is the width of the output). You may not like “what you get” because the annotations will be fairly tiny.
Hope this helps.
--Jon
Jon Balgley
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
John,
Can you explain the process that is used to alter the resolution of the images from within the templates?
I have Adobe Acrobat Standard, but I can't seem to figure out how to edit the resoultion.
Alex
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
First off, we recognize that the following is inconvenient, at best.
In order to do this for PDF, you need Adobe Acrobat or another tool capable of editing PDF files.
1. In Acrobat, open the appropriate PDF template file, found here:
- Windows XP - \\Documents and Settings\All Users\Application Data\Autodesk\Inventor Publisher XXXX\Templates
- Windows Vista - \\ProgramData\Autodesk\Inventor Publisher XXXX\Templates
2. Use “Forms --> Add or Edit Fields…”
3. Find the “Snapshot/Image[640x480]” field.
4. Change the name to be “Snapshot/Image[1600x1200]” … and use the actual size of your Publisher window, in pixels, for the “width-x-height” values.
This same concept applies for publishing to Word and Powerpoint. Publisher automatically uses “window size” by default when publishing to “image” formats.
If you have further questions or comments, please reply here.
Jon Balgley
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks John!...I'll give it a try
