• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    robert.ruhe
    Accepted Solution
    Enhanced Vector Publishing question
    583 Views, 3 Replies
    12-28-2012 10:09 AM
    In an effort to work around the problems I've had, I found that I can get much faster response times in Publisher if I import a DWF file instead of IAM files. But I find that I can't publish to enhanced vector when I use DWF files. My question is this:  Of the list of files that can be imported into publisher that can then be published with the enhanced vector option is there one both improves overall performance vs IAM files and that CAN be published to the enhanced vector option?  Yes I can export Publisher files using DWF as source - but it's in the "old" vector publishing format which gives unacceptable results. I'd really like to find a work around that can both speed things up for me without limiting my vector (and other) options.
    Secondly - is there any chance that DWF files will someday be able to use the enhanced vector option - or is this an inherent impossibility?
    I'd love to hear about any upcoming SP4 news or about new features in the future 2014 version of publisher.
    Thanks!
    Please use plain text.
    Employee
    Re: Enhanced Vector Publishing question
    01-04-2013 11:48 PM in reply to: robert.ruhe
    Enhanced vector output use Inventor translator to do the output, it only suport Inventor data source.
    Inventor data source contain:-- Inventor files (IPT and IAM), Catia files, UG NX files(prt), solid works files, Pro/E, JT, SAT, STEP files, parasolide files etc. All above files can use Enhanced Vector output.
    DWF is not a kind of inventor date source.
    Could you try to import different LOD when inport Inventor files? or, you can create some substitute in the LOD files, it can short the import response time.
    Peggy Wang
    Sr. Software QA Engineer
    Publisher Quality Assurance Team
    Autodesk, Inc.
    robert.ruhe
    02-18-2013 07:17 PM in reply to: peggy.wang
    Peggy,
    Can you give me a way to upload a file to you for examination? My frustration with Publisher is reaching a crescendo and I am either going to fight through it or abandon the software altogether.
    My expectation is that if Inventor can create highly complex models with many parts, then Publisher should be able to work with the same models without issue. Is that unrealistic? I would love to find a solution to this unknown error in vector publishing. I have no idea if it's the model itself or the software. Our designers swear up and down that the models are problem free. But they are not looking at this from a Publisher viewpoint. So maybe they're missing something.
    At the end of the day, I feel handcuffed having to tweak settings and other things in Publisher just to keep it going. The performance comparisions between Inventor and Inventor Publisher are remarkable. Inventor itself is fast, sleek, and never gets tired. Publisher behaves like a sick horse. And I've run it on three different machines. My main system is very well equipped to handle the requirements for Publisher - yet it's slow, has these unknown errors... and if you haven't figured out yet, it's making me crazy. I apologize for the rant - but I really need to find an answer to this. I am very much an Autodesk supporter - but this particular piece of software is making me lose my mind.
    At the end of the day, I shouldn't have to worry about the software at all. I should be able to just focus on what I am making. But Publisher has been quite frustrating - and I want to love it. I really do.
    Employee
    02-18-2013 10:39 PM in reply to: robert.ruhe
    Hello robert.ruhe
    I need get your email to send out the invitation , then you can upload the dataset to Autodesk File transfer server. Please send an email to me wang.ping@autodesk.com
    Peggy Wang
    Autodesk, Inc.
