• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    Distinguished Contributor
    BLHDrafting
    ENHANCEMENTS BADLY NEEDED
    530 Views, 3 Replies
    12-16-2012 06:09 PM
    Just started using Publisher 2013 and I have found functionality missing. Below are some enhancement requests I would like to see in the software, some of which may have already been covered :-
    1. Configurable mouse wheel zoom direction
    2. Be able to set the background/sytle/shadows etc on the first Snapshot and push it to all following snapshots, at the end of the snapshot series or any time after the initial start of the session. I just had to change these 3 settings for 30 odd snapshots,
    3. Make the items outside of the Publish Area disappear (seeing them just confuses the display)
    4. Have control of font, size, colour, bold/italic and such on Callouts
    5. Be able to move a sub-assy, not just it's parts. Having to select each of the sub-assy parts and group move them is a pain. Have not tried issuing MOVE from model tree - this may work?
    6. Remove (configuration/Application Options?) the transparency of stuff. Again it complicates the display!
    7. Have the model tree (canvas?) fully docked (like Inventor) and not transparent
    8. Add (improve?) the range of and use of dimensions
    9. Enhance the GUI so it is more Inventor like. It's way different and not intuitive (I guess this product is heading down the Fusion path - a turn off for me)
    10. Improve the "grip" when placing a Callout and when wanting to move that callout arrow. It's a dog!
    11. Make it more intuitive with Vault. If I have opened from a Project then adding images and such should point back to the project, not to root directory of C drive or to My Documents. Same when publishing Images or PDF or movie, it should know I the project and sub-folder I am in.
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
    Please use plain text.
    Employee
    Re: ENHANCEMENTS BADLY NEEDED
    12-20-2012 08:48 PM in reply to: BLHDrafting
    Hi Brendan,
    Thanks for your feedback, please see my comments below,
    1. This is a wishlist in our tracking system,
    2. Inventor Publisher has already have this function, you can right clck  the current snapshot and select Set Affected Snapshots> All Snapshots
    3. It depands on which output you used.
    4. For the annotation font, size, color, bold,etc, you can do the change on the Annotation tab in the Ribbon.
    5. When you have the sub-assy selected, and then use move button, then it works.
    6. I can't understand what's the meaning of it
    7. As design, I will add it as wishlist to our issue tracking system.
    8. Dimension improvement? could you add more detail information about this? what do you want?
    9.10,11 Need more information
    Irene
    Inventor Publisher QA
    Member
    03-07-2013 10:17 AM in reply to: BLHDrafting
    Add to this, the ability to use design representations from the assembly model. This would make Publisher some much more useful. They are already created in the Inventor model and ready to be used in a presentaion, but I can access them. If I'm missing something, please advise.
    Steve
    Employee
    03-13-2013 01:08 AM in reply to: BLHDrafting
    Hello Steve,
    You suggestion is counted, and i have added your comments into issue Nov-6181, It is a wishlist to support Non-master Position Represition import from Inventor.
    Peggy
    Peggy Wang
    Sr. Software QA Engineer
    Publisher Quality Assurance Team
    Autodesk, Inc.
