• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    Active Member
    Determine linked parent
    312 Views, 1 Replies
    06-15-2010 09:34 AM
    Is it possible to determine the name and path of the linked .iam file from within Publisher?
    Please use plain text.
    Employee
    Re: Determine linked parent
    06-15-2010 10:18 AM in reply to: clennon
    No, this information is not exposed for IAMs.  For IAMs, we do keep the file name and path internally, for use by the Update command.  The root of each inserted IAM (i.e., first-level node in the tree) shows the name of the file you inserted, but the subassemblies and parts show the occurrence names from the assembly (usually but not always the file name).
    DWF files created from IAM files will show the IAM file name at one level further down.
    I'm curious as to why you need this.  Did you just "forget" where it came from?  Or is there a more complex workflow?
    Jon Balgley
    Autodesk Inventor ETO team
