• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Publisher
    hole423
    Configuration File
    151 Views, 1 Replies
    03-25-2011 07:19 AM
    Is there a file or files that contain the settings that I can transfer to another seat.  Example:  I set up a few material colors as favorites and I would like to take those favorites and deploy them to other seats so that we have uniform color chooses.
    Currently I am working in Publisher 2011 R1 and I am getting ready to switch to 2012.
    Please use plain text.
    Employee
    Re: Configuration File
    03-28-2011 09:44 AM in reply to: hole423
    We store Favorite Materials as a user prefernece today. We don't yet have an "official" way of transfering the preferences, but here is a potential workaround that you can try:
    1. Locate your Publisher Preferences directory. This directory is in your Operating System's appdata folder. For Windows 7 64-bit with an English Locale, it is located here:
    C:\Users\[user name]\AppData\Roaming\Autodesk\Inventor Publisher 2011\en-US
    2. In this folder, there is an XML file "Publisher-Settings-Material.xml". This file contains your material and color preferences. If you copy this file and drop it in another user's preferences folder, the application should pick it up and give the other user the same material and color preferences as you have.
    -Manjiri McCoy
    Software Developer, Inventor Publisher
