• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    Active Contributor
    marshallw
    Cannot Manually Explode (Move) Single Instances of parts
    480 Views, 3 Replies
    04-05-2010 09:58 AM
    Has anyone else had problems selecting individual instances of parts for some form of editing mod? Please see attached ZIP. Am I doing something wrong here?
    Please use plain text.
    Employee
    Re: Cannot Manually Explode (Move) Single Instances of parts
    04-07-2010 01:42 PM in reply to: marshallw
    The short answer is that you cannot do this, on an inserted IAM file, because (presumably) the part is a component of a subassembly that is instanced several times. Publisher currently works on the subassembly's "component definition" hence all instances are affected.
    The only workaround is to export your Inventor assembly to DWF, and then insert the DWF file instead of the IAM. DWF does not have a concept of a "definition", hence does not behave this way (each subassembly is independent, even if identical).
    The biggest (only?) downside of this workaround is that you cannot take advantage of Publisher's "update" mechanism.
    As a separate point, note that you cannot explode a single part, only an assembly or selection-set containing multiple parts. The parts are exploded away from each other, so "of course" you cannot explode just one.
    Jon Balgley
    Autodesk Inventor ETO team
    Autodesk, Inc.
    Employee
    06-18-2010 09:24 AM in reply to: Jon.Balgley
    Please apply for Beta testing.  Software is available now!
    http://forums.autodesk.com/t5/Autodesk-Inventor-Publisher/Beta-is-now-available-testers-wanted/td-p/...
    -Sam
    Sam Antos
    Autodesk, Inc.
    New Member
    ptal
    06-20-2010 10:10 PM in reply to: Jon.Balgley
    But why can't you even turn off visibility for the separate instances?
    It's bad enough that you have to move them together - Or should I say you can't - because you move 1 and they all move, but if you select multiple to move - it fails to move any.
