• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    Member
    s.holland.cmc
    Accepted Solution
    Cannot Insert Assembly due to Custom Library
    155 Views, 3 Replies
    03-22-2011 07:25 AM
    Whenever I try to insert an assembly that contains parts from my own custom library (not located in the same file as the assembly) I recieve an import failure message stating that it can't find the part.  However, I can open that part from the library location just fine in publisher.  Is there a setting I can change, rather than having to copy all my parts into separate folders everytime I make an assembly?
    Please use plain text.
    Employee
    Re: Cannot Insert Assembly due to Custom Library
    03-22-2011 11:45 AM in reply to: s.holland.cmc
    Are you using the "project file" option from the Insert dialog?  The "Options" button is only enabled once you pick the IAM file.
    Jon Balgley
    Autodesk Inventor ETO team
    Autodesk, Inc.
    Member
    s.holland.cmc
    03-22-2011 12:28 PM in reply to: s.holland.cmc
    No, I didn't use that.  Thank you for pointing that out.  Is it possible to assign a project after you have inserted an assembly?
    Employee
    03-22-2011 02:39 PM in reply to: s.holland.cmc
    Glad to help.  I know it's not obvious -- that's why I mentioned it.
    The project file is ony used at import-time.  Once the assembly is in, it's in.
    Jon Balgley
    Autodesk, Inc.
