• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Publisher
    Valued Contributor
    dherman469
    Apply a Material change to all storyboards at once? Publisher 2013
    462 Views, 9 Replies
    05-09-2012 09:09 AM
         I have a file with several storyboards created.  I would like to change the material appearance for a component that is seen in all three storyboards.  However, I seem to only be able to change the component in one storyboard at a time.  In other words, changing the material of a component in one storyboard does not change it in the others.  Is there a way for me to modify the material appearance of a component in all storyboards at once?
    Daniel Hermanson
    Spraying Systems Co.
    Please use plain text.
    Distinguished Contributor
    bowen192
    Re: Apply a Material change to all storyboards at once? Publisher 2013
    05-10-2012 03:26 AM in reply to: dherman469
    Have you tried the following:
    Ctrl/Shift and selct the snapshots to be affected
    Right-click on one of the selcted snapshots > Set Affected Snapshots > Select Snapshots
    Make your changes.
    Don't forget to unselct the snapshots :smileywink:
    Valued Contributor
    dherman469
    05-10-2012 05:39 AM in reply to: bowen192
         I tried what you suggested.  However, that still seems to only affect all the snapshots in that one storyboard.  I can't seem to "activate" two storyboards at the same time to change materials in both in one shot.
    Daniel Hermanson
    bowen192
    05-10-2012 06:23 AM in reply to: dherman469
    The same should be true but by selecting the Storyboards instead.
    The illustration inside the Snapshot/Storyboard isn't always live btw.  Have you actually checked inside the Storyboard?
    Valued Contributor
    dherman469
    05-10-2012 06:38 AM in reply to: bowen192
    I think I finally got what you were saying.  I simply wasn't reading the entire screen window.  When I was setting the affected snapshots to All Snapshots or Following Snapshots, I stopped reading when I got to those choices in the Within Storyboard box.  I never continued reading down to see that I could affect the snapshots in the entire document.  Once I click on All Snapshots within Document, all my storyboards could be updated to the material change at once.  I feel really dumb now.  Ha, ha. :smileywink:
    For those of you like me that don't read everything completely, I attached a picture showing.
    Daniel Hermanson
    Active Contributor
    07-09-2012 07:17 AM in reply to: dherman469
    It is not working for me!
    when do you select your object to change the material?
    before ctrl/shift selecting snapshots or after?
    Can you please instruct me step by step?
    Cheers
    Ali
    Valued Contributor
    dherman469
    07-09-2012 08:23 AM in reply to: jahed.ali
    Hello Ali,
         These steps have worked for me.  I have attached pictures to help show the steps better.
    1)  Right click on the current active snapshot and choose: Set Affected Snapshots---Within Document---All Snapshots.
    If you only wanted the change to affect a single storyboard, then you would choose that option instead.
    2)  You can now right click on the particular component that you want to change, and choose: Material.  This brings up the color chart and material choices.  For my example, I will simply change the part to be Red in color.
    3)  Now you have to go to each storyboard in your document, and you will see a bunch of lightning bolts in the snapshots.  Right click on the name of the storyboard and choose: Update Thumbnails.  This will update the color change to all the snapshots in that storyboard.  You will need to do the update in each storyboard.
    I hope that this helps.
    Daniel Hermanson
    Active Contributor
    07-09-2012 11:53 PM in reply to: dherman469
    Thanks mate,
    It didn't work at first I closed the file and re-opened then it worked.
    Again and again I have to say this software has seriouse problems.
    Valued Contributor
    dherman469
    07-10-2012 05:02 AM in reply to: jahed.ali
         It does have some bugs, but I try to remember that this is only the third release of the program.  I remember when I tried using the first couple releases of Inventor.  That was pretty bad, but over time it improved tremendously, and I love using it.  I'm pretty sure that Publisher will get where it needs to be.  It will just take time.
    Daniel Hermanson
    Employee
    TimeraAutodesk
    07-11-2012 10:38 AM in reply to: dherman469
    Great point, Daniel - while we do our very best to deliver a superb experience, it is important to keep in mind that bugs are a natural part of the "maturing" process for any piece of software. We are pleased with how much Publisher has matured in the short 3 years we've been around, and are looking forward to some exciting improvements to come as well :smileyhappy:
    Timera
