• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Engineer-to-Order
    set iProperties
    211 Views, 7 Replies
    08-16-2012 10:48 AM
    I'm trying to set the iProperties value Mass.  I'm using a placeholder block to cut down on the graphics load, but I still want the part to reflect the correct weight load and weight distribution.  I'm starting with the flollowing code:
    child block as :block, quantity = 4
        iProperties = {{"Mass", 8}}
    end child
    the value shows up here
    but not here
    how do I pass the value through?
    Andrew
    Please use plain text.
    Employee
    Re: set iProperties
    08-16-2012 04:23 PM in reply to: alundr
    Not sure why this isn't working for mass properties. The same technique seems to for custom properties, e.g.
     iProperties = {{"test", 200.0}}
    Then a custom property is added:
    Employee
    AlexKorzun
    Re: set iProperties
    08-17-2012 06:42 AM in reply to: alundr
    iProperties are stored in the Inventor document/file (IPT, in your case). If you switch to the ClientGraphics implementation of the block, there will not be a document behind it.
    You may consider adding the Parameter/Rule to keep the value of the mass.
    Thank you,
    Alex Korzun
    Principal Engineer
    Re: set iProperties
    08-17-2012 07:05 AM in reply to: alundr
    I'm not sure what you mean by "adding the Parameter/Rule to keep the value of the mass".
    What are ClientGraphics?
    Do you have an example of how I would go about doing this?
    What do you mean by "keep the value of the mass"?
    Andrew
    Employee
    AlexKorzun
    Re: set iProperties
    08-17-2012 07:42 AM in reply to: alundr
    Create new Design that extends block:
    Design BlockWithMass : Block
    	Rule Density As Number = 10.0
    	Rule Mass As Number = Me.width*Me.height*Me.length*Density
    Parameter Rule Mass1 As Number = 0.0 End Design
    Create the child list in your assembly:
    Child block As :BlockWithMass , Quantity = 5
        width = child.index
        height = child.index
        length = child.index
        origin = Point( child.index*2, 0, 0)
        Mass1 = 8.0
    End Child
    Please note that Mass is a Rule (which is calculated from the block size), and Mass1 is a Parameter, that can be specified during creation of the BlockWithMass
    Mass of the block 3 will be determined as:
    Intent >block_3.mass
    --> 270.0
    Intent >block_3.mass1
    --> 8.0
    Intent >
    Thank you,
    Alex Korzun
    Principal Engineer
    Re: set iProperties
    08-17-2012 11:29 AM in reply to: AlexKorzun
    what does the iv_setProperty method do/how does it function?
    Employee
    AlexKorzun
    Re: set iProperties
    08-17-2012 12:14 PM in reply to: alundr
    The first argument to the function iv_PropertyPut should be an Intent Part. The implementation tries to find the Inventor Document that owns the property.
    In your case, Block will not have the Inventor Document behind it, so Intent will try to find the Document in Block's parent.
    Thank you,
    Alex Korzun
    Principal Engineer
    Employee
    Re: set iProperties
    08-19-2012 12:52 PM in reply to: AlexKorzun
    If you're not able to set the mass using the default iProperties rule, as a workaround you can implement your own that calls the Inventor API, for example:
    Method UpdateMass(Mass As Number) As Boolean
     Try
      Dim invApp As Any=%%InventorApplication
      Dim activeDoc As Any=invApp.ActiveDocument
      If activeDoc<>NoValue Then
       If activeDoc.DocumentType=Inventor.DocumentTypeEnum.kPartDocumentObject Or _
             activeDoc.DocumentType=Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        Dim massprops As Any=activeDoc.ComponentDefinition.MassProperties
        massprops.Mass=Mass
        Return True
      Return False
     Catch Error
      Return False
     End Try
    End Method
