• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Engineer-to-Order
    Distinguished Contributor
    ludesroc
    run DLL
    91 Views, 4 Replies
    12-20-2012 11:30 AM
    I'm trying to run a simple .dll from ETO but can't acheive anything!!!!
    Here's my approach:
    Copied the .dll is in the Design Files folder of the current project.
    Tested in ETO --> Rule myValuesAdded As Number = ClassLibrary1.Class1.AddMyValues(5, 2)
    I get --> No such method 'AddMyValues'  while calling (static) on ClassLibrary1.Class1
    ' Here is the dll...
    Public Class Class1
      Public Function AddMyValues(ByVal Value1 As Double, ByVal Value2 As Double)
        Dim Result As Double
        Result = Value1 + Value2
        Return Result
      End Function
    End Class
    ' Created a simple form to test the dll...it works just fine!!!
    Imports ClassLibrary1
      Public Class Form1
        Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
          Dim Add As New ClassLibrary1.Class1
          TextBox3.Text = Add.AddMyValues(CDbl(TextBox1.Text), CDbl(TextBox2.Text)).ToString
        End Sub
      End Class
    Any help would be appreciated.
    Ludesroc
    Please use plain text.
    Employee
    Re: run DLL
    12-20-2012 12:19 PM in reply to: ludesroc
    See if the attached helps (code from Jon Balgley's Potlatch presentation on this topic).
    Intent rules:
          Rule cus1 = New vbclasslib.customer("Jon", "Balgley", "503-555-1234")
          Rule cus2 = New vbclasslib.customer("Jon", "Yelglab", "503-555-4321")
          Rule allCus = { cus1, cus2 }
          Rule allPhones As List
                For Each C In allCus
                      allPhones = allPhones + {c.phone}
                Next C
          End Rule
    Sanjay-
    ludesroc
    Re: run DLL
    12-20-2012 12:45 PM in reply to: sanjay.ramaswamy
    Hi Sanjay,
    When evaluating allPhones, I get this error...
    Error - vbclasslib.customer
    Error Message:
    vbclasslib.customer
    Rule Stack:
    Part: Root
    Rule: cus1
    Design: ViewWindow
    Source:
    Part: Root
    Rule: allCus
    Design: ViewWindow
    Source:
    Part: Root
    Rule: allPhones
    Design: ViewWindow
    Source:
    Next C
    End Rule
    Part: Root
    Rule: %%EVAL_TEMP_1
    Design: ViewWindow
    Source:
    Uncached Rule %%EVAL_TEMP_1 As Any = allPhones
    Are there any other steps to follow prior to run a dll from ETO?
    1- I closed Inventor
    2- Copy the dll in the design files folder (of current project)
    3- Restarted Inventor
    4- ...
    Ludesroc
    FarrenYoung
    Re: run DLL
    12-20-2012 02:02 PM in reply to: ludesroc
    Try this instead
    Public Class Class1
      Public Shared Function AddMyValues(ByVal Value1 As Double, ByVal Value2 As Double) As Double
        Return Result
      End Function
    End Class
    --Farren
    If this post helps, please click the "thumbs up" to give kudos
    If this post answers your question, please click "Accept as Solution"
    FarrenYoung
    Re: run DLL
    12-20-2012 02:07 PM in reply to: ludesroc
    If you don't want static methods in your .net code, you could get an instance in your intent code.
      Dim instance As Any = New ClassLibrary1.Class1()
      Return instance.AddMyValues(5, 2)
    End Rule
    --Farren
