Autodesk Inventor Engineer-to-Order
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Work with Intent Design Editor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried it too, and could not reproduce it. I had an Intent design, inheriting from IvDrawingSheet, blank sheet showing in Inventor. In the Design Editor, I tried adding "view" Child rules, using "." in numbers, and it all worked. Sorry!
(It worked OK in ETO Studio -- Visual Studio, too.)
Jon Balgley
Autodesk Inventor ETO team
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have an idea. Is your operating system not en-US? Is your installation not en-US? This might be why we cannot replicate. And since the failing thing appears to be some kind of string comparison, it might be related.
--Jack Gregory
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you please to see this video.
https://www.dropbox.com/s/nxmbxf2tiikdcax/20130130
I have en-US version. Our company is located in California.
I don't understant why I have this issue after reinstalling ETO. Before I didn't have it and I didn't change Intent code.
The problem is just with numbers.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We don't understand, either. I could not read anything in the video, but I see that you tried several files and only one has the problem. But this file has a LOT of content. It was not what you described as steps to replicate, which Jon tried to follow. Can you send me that file? All the evidence is that there is something about this particular file. Even if you can get it to happen with ANY file, send the failing file to Jack.Gregory@Autodesk.com.
I know this is painful, but these kinds of things usually are. There is something here which we did not see in testing, and we need to understand.
Also: You said it fails in ETO Studio. Can you send me the backtrace for that failure as well? We can take this off the discussion group and then report back to everyone when we have something.
--Jack Gregory
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried recreating the error from what I understand. I used the SheetMetal assembly in the ETO 2013 samples. It has a drawing. In the design for SMDrawingSheet I tried entering the double for values. (.22, 0.4) I attached a screenshot to show what I did.
Can you upload a small dataset that I can use to recreate this error? Another screenshot of your ETO dialogs would help too.
Thanks!
Wayne Brill
Developer Technical Services
Autodesk Developer Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A little bit wrone. I don't have any problems with particular file. The problem is when I try to modify the sheet design file and have active drawing what has been created from this sheet design file. I have 25 drawings and 25 sheet desing files respectively. When I generate any drawing through the Intent I have issues with sheet design file that has relation to active drawing. If I close drawing I can do with sheet design file whatever I want.
In previous post I have saw screenshot, hovewer, it's Visual Studio, not Intent Design Editor.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The AVI you posted to drop box is of Intent Design Editor. It fuzzily shows that in the Title Bar.
In Design Editor, in the View menu, there is a check box to turn Intellisense off. Could you uncheck that and see if you have the same problem? If you still have an exception, please send the full backtrace so we can see what is different.
--Jack Gregory
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have tried to turn off intellisense. No changes. I can send to you my sheet design file, but I'm not sure you can run it. We have a difficult design structure. We use own application for working with database. I mean transfer all needed variables from database through this application. Build 3D model and set of drawing runs from application as well. I tried to use Visual Studio, hovewer, Intent model didn't load into VS. One more thing. We have 2 the same machines what using the same Intent design files. On my machine has been installed ETO R2, on the second machine - ETO R1. On my machine exist this problem, on another machine not.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
After many trials and guesses, we have replicated this problem. It occurs when there is a conditional child rule (the Design is conditional). It is also a separate defect that turning Intellisense off does not stop the problem from happening. The problem has nothing to do with drawings. It is replicable with a trivial Design.
This problem is not present in ETO Studio. That is the recommended workaround until a fix can be released.
--Jack Gregory
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for explain.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
