Autodesk Inventor Engineer-to-Order
- Start Article
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Work with Intent Design Editor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Couple days ago I have installed ETO R2 2013. When I work with Intent Design Editor I have some issue. When I try to input double number (as 2.25) I have some error message (see attached picture). What is it? How can I fix it?
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
Re: Work with Intent Design Editor
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In addition, the error message shown after input "."
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you send or post the file that gets the error?
Hard to give much advice without seeing it.
--Jack Gregory
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Too hard to say what file gets this error. I have this issue when I work with sheet in Intent through Design Editor.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK. The next time you see this problem, please send (or post here) the full backtrace as shown in that error dialog, and the file you are editing at the time. It looks like an intellisense error, which should be something we can track down.
--Jack Gregory
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is exception text.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
at Autodesk.Intent.Utilities.EqualsName(String name1, String name2)
at Autodesk.Intent.UI.DesignEditor.IntelliSense.Membe
at Autodesk.Intent.Common.UI.SyntaxEditor.SyntaxEdito
at ActiproSoftware.SyntaxEditor.SyntaxEditor.OnTrigge
at ActiproSoftware.SyntaxEditor.SyntaxEditor.a(Trigge
at ActiproSoftware.SyntaxEditor.SyntaxEditor.a(Editor
at ActiproSoftware.SyntaxEditor.SyntaxEditor.OnKeyPre
at System.Windows.Forms.Control.ProcessKeyEventArgs(M
at System.Windows.Forms.Control.WmKeyChar(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at ActiproSoftware.SyntaxEditor.SyntaxEditor.WndProc(
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you tell us how you are getting this error? I need some steps to replicate.
--Jack Gregory
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have open sheet of drawing through Intent.
Child FrontView As ...
End Child
Child RightView As ...
End Child
Child PartsList As ...
End Child
Child Notes As ...
End Child
Every time when I try to type number (double type), after typing "." I have message shown above. It doesn't matter where I try to type number. In ETO R1 I didn't have with issue.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry, I am unable to replicate this with the information given. Does anyone else have this problem?
I suppose I should say that ETO Studio is the preferred/recommended rule editing environment over Design Editor starting with Inventor ETO 2013 R2.
--Jack Gregory
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It doesn't matter what I use. Visual Studio or Design Editor. It must work. About previous information. For replicate this issue you need to create drawing through Intent. When you will have blank sheet on the screen. Go to into sheet design and try to type any double number. Done.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
