• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Engineer-to-Order
    Active Contributor
    Accepted Solution
    Sub-Assemblies change their Document Settings \ Units
    113 Views, 1 Replies
    01-28-2013 08:41 AM
    Hello All,
    The sub-assemblies called in as children change their document Units of Measurement from Inches to Centimeters:
    Even though all the sub-assemblies were originally made from the Inches template (Automation(in).iam) (with all the parameters being passed in inches), and if I open them individually, they are in still in inches.
    But when they are added as children, the document settings change to make them set to cm.
    Example at hand:
    (Main Assembly, with the documents settings being inches)
    (if I drill into a sub-assembly, the document settings show that units have changed to cm)
    All help is appreciated.
    Thanking you,
    Wajih
    Please use plain text.
    Employee
    Re: Sub-Assemblies change their Document Settings \ Units
    02-04-2013 07:18 PM in reply to: WHassan
    Hi Wajih,
    It appears to be a known problem that the unit of the sub-assembly will changed after its called in as children in some cases, which we are looking into, you may need to manually change the unit for now.
    Amanda
