Autodesk Inventor Engineer-to-Order
- Start Article
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Sectioning Convention s for Webs and Ribs
- Highlight
- Email to a Friend
I have seen posts form previous years about the problem of Inventor not following sectioning conventions in drawings.
I think it is very uncomfortable to have to manually re-hatch drawings to follow standard practice, or make my single parts as an assembly to ignore sectioning some features. I think its absurd to do this for every part I want to section correctly.
Since I have seen forums on this subject dating from 2006, I think its incredible that Autodesk hasn't come up with a solution to this yet. Is it not time for you guys to modify the drawing rules so that your software actually does professional engineering work?
I've heard Solidworks can do it and you guys don't.
For an issue that has been posted for more than 6 years, I think that it's a barbarity that it is not yet fixed appropietely,
Just saying...
Re: Sectioning Convention s for Webs and Ribs
- Highlight
- Email to a Friend
Two things.
1. You're posting this in the wrong forum (try here... http://forums.autodesk.com/t5/Autodesk-Inventor/bd
2. If this was as big of a deal as you're making it out to be lots of others would be complaining and it likely would have been added to Inventor by now. Autodesk conducts surveys each year to ask users what they want/need in the next version of all their applications. This must not have been too high on their results. So you have a couple options. You could always use solidworks or you could program a fix for yourself.
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
- Highlight
- Email to a Friend
Thank you for your reply.
Sorry for posting in the wrong section.
With regards to the solution, the choice of the software is not mine, it's my employer's. So a solution from Autodesk would be nice. I'm pretty sure I am not the only one pointing this out, since, like I said, there are several post about this issue dating back as far as 2006.
- Highlight
- Email to a Friend
Since the feature doesn't currently exist and you are unable to use other software, you could probably get help with a custom programmed solution from this forum: Autodesk Inventor Customization - Autodesk Discussion Groups
This isn't ideal, but if it saves you time it's better than nothing.
- Highlight
- Email to a Friend
Thank you very much.
