Autodesk Inventor Engineer-to-Order
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Run project with VS2010!!!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The first time you try after a reboot, Visual Studio doesn't connect with Inventor?
After it makes a connection, are you able to close VS and Inventor, then restart them and reliably get a connection?
Mike Deck
Software Developer
DLS - Mechanical Design
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Run VS -> Open Project -> Run Inventor -> Create empty Intent assembly through "Create new file" -> There is a connection between Intent and VS -> Close assembly -> Open my app -> Generate 3D -> There is a connection -> Close Inventor -> Close VS -> Run VS -> Open Project -> Run Inventor -> Run my app -> Generate 3D -> No connection.
I need to repeat trick with empty Intent Assembly for creating connection between Intent and VS every time when I close VS.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
After you get a connection and Generate 3D: can you close that model, Generate 3D again and get a connection? Or do you have to Create New File again?
Mike Deck
Software Developer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, I have a connection if I close 3D and generete again through my app. It works so long as VS is open.
Xeon X5647
24 Gb RAM
Quadro FX 6000
Inventor 2013
ETO 6.1, Build 140.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't know what is causing the problem. We will try to reproduce it.
Mike Deck
Software Developer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am not able to get a connection to VS using the approach above. I am able to run the solution from VS to launch a new instance of Inventor, but the debugging cycle time of that approach is too long (waiting on Inventor to start).
Are there some settings in VS that I need?
I had trouble throughout the weekend trying to use ETO Studio R2. I have done the following already:
- uninstalled all custom add-ins
- uninstalled all Autodesk products
- Reinstalled ETO Studio R2 with all available options (Inventor, content center, etc)
- Started a new ETO design library project/solution from VS.
- Set that project as the active project in Inventor
- Followed your steps above to get the connection to VS.
- No luck. Screenshots are attached.
George
Dell M6400
i7-2820QM @ 2.3GHz Quad Core
16GB RAM, 256GB SSD, Quadro 2000M
Windows 7 x64, SP1
Inventor 2013 - Build 138
ETO 6.1 - Build 140
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I want to make sure you know that you can't debug Intent code even if you do get a connection this way. The only way to debug Intent code is to start Inventor from Visual Studio.
Do you have any Visual Studio add-ins or extensions loaded? Can you post the About dialog from your install of Visual Studio?
Mike Deck
Software Developer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Mike,
I learned that from the team here this morning. That is a bummer. I will be logging ADN issues with our discoveries on projects that depend on reference project libraries relative to performance when we run Inventor from VS for debugging.
George
