• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Engineer-to-Order
    Run project with VS2010!!!
    172 Views, 17 Replies
    01-31-2013 10:19 AM
    Please see the next order for generating 3D and drawings.
    Run Inventor ->
    Run Add-in (has been created for transfer data from database to Intent and works as interactive app for update some 3D model parameters) ->
    Open Job # (transfer data from database to app) ->
    Build 3D (build-in option into app).
    All variables transfers to Intent through Dynamic Rules as lists. All children parameters in Intent have a references to particular variables in the Dynamic Rules.
    Intent starts generate the 3D model.
    Model was builded.
    As user I can change some parameters through app and update their through the build-in option in app as "Update Parameters". In this case app override Dynamic Rules and update 3D.
    If I need to change some Intent code I open Intent Design Editor and do it.
    Now I try to do the same with VS, but then I have active Intent model VS is empty.
    I can see full structure of my project in VS (Design Navigator). I can see all my Design files (Solution Explorer).
    Hovewer, ETO Model Browser, ETO Model Properties shows me message "There is no Intent model loaded in Inventor". How it possible? In Inventor the Intent model is active.
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
    Please use plain text.
    Employee
    Re: Run project with VS2010!!!
    01-31-2013 12:17 PM in reply to: omarutov
    Please try this test:
    - Close Inventor and Visual Studio
    - Restart Inventor and VS
    - in VS, load your solution
    - in Inventor, create a new model with the "Create a new design automatically" option
    Does VS connect to Inventor in this case?
    Mike Deck
    Software Developer
    DLS - Mechanical Design
    01-31-2013 12:32 PM in reply to: MjDeck
    No. I don't use menu "Create new file" as Intent Assembly. I use our app for that.
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
    Employee
    01-31-2013 12:36 PM in reply to: omarutov
    I'm recommending trying to create a simple empty Intent assembly only as a test. It might help us to figure out what is causing the problem between Intent and Visual Studio.
    Mike Deck
    Software Developer
    01-31-2013 12:37 PM in reply to: omarutov
    Yes, I have a connection with VS if I use your proposal.
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
    Employee
    01-31-2013 12:42 PM in reply to: omarutov
    OK, thanks.
    Try closing that empty model, and then create one of your own models.  Do you get a connection?
    If not, please use the About Inventor (or About Inventor OEM) command and post a screenshot of the About dialog.
    Mike Deck
    Software Developer
    01-31-2013 12:55 PM in reply to: MjDeck
    Yes, I have got connection.
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
    Valued Contributor
    02-01-2013 07:38 AM in reply to: omarutov
    Hovewer, I need to repeat this way every time when I restart my machine. What would you propose?
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
    Employee
    02-01-2013 08:17 AM in reply to: Lesoux
    Lesoux, did you upgrade to ETO 6.1?
    Mike Deck
    Software Developer
    Valued Contributor
    02-01-2013 08:22 AM in reply to: MjDeck
    I have ETO R2. Sorry, I didn't update my signature.
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
