• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Engineer-to-Order
    Active Contributor
    Editing items in a list
    148 Views, 3 Replies
    11-30-2012 08:21 AM
    Hi All,
    I am tyring to edit a mulitilevel/multiDimensional list but I am getting a compile error.
    What I am trying to do is;
       1. to generate a list of parameters for listed children
       2. edit the created list based on a few conditional checks
    Now the list is created and is working fine, but when I want to edit an item in the list; I am getting the comlie error.
    Here's what my rule looks like:
    Rule lstPreStdPanels As List
        Dim panelCounter As Integer
        'loop to create the panel parameters list
        For panelCounter = 1 To intNoStdPanels
            lstPreStdPanels = lstPreStdPanels + {{ _
            ":smileysurprised:rigin", Point(panelCounter * StdPanelLength,0,0), _
            ":xDirection", Vector(0, -1, 0), _
            ":yDirection", Vector(-1, 0, 0), _
            ":smileytongue:anel_length" , StdPanelLength }}
        Next
        Dim openingCounter As Integer
        'Loop through the opening list to check if need changed length
         For openingCounter = 1 To length ( lstOpeningList )
            If nth (5, nth( openingCounter , lstOpeningList ) ) = "T" Then
                    'Determine the target panels
                    If GetX(Second(nth(panelCounter,lstPreStdPanels)) >50 Then
                       'nth(8, nth( panelCounter, lstPreStdPanels ) ) = 5
                    End If
                Next' panel counter
            EndIf' If opening List = T
        Next' openings counter
    End Rule
    I am getting the error on the commented line.
    I could try to place the conditional checks as the list is generated, but I have more that one conditions which are themself in a loop (in contrast to this sample code).
    All help is appreciated.
    Thanking you,
    Wajih
    Please use plain text.
    FarrenYoung
    Re: Editing items in a list
    11-30-2012 10:56 AM in reply to: WHassan
    Editing an element of a list is not possible in the intent language as you have shown.  I have worked around this before by creating a replaceItem function which takes a list, an element index, and a newValue and essentially splits the originally list at the index, excluding the item to replace and builds a new list inserting the newValue between the start and end pieces of the two parts of the list.
    --Farren
    If this post helps, please click the "thumbs up" to give kudos
    If this post answers your question, please click "Accept as Solution"
    Active Contributor
    11-30-2012 11:41 AM in reply to: FarrenYoung
    Could you please post/attach the function/snippet.
    Trying to accomplish what I had asked has exhausted: I am out ideas.
    A fresh perspective would be a re-boot.
    Thanking you,
    Wajih
    Active Contributor
    Chris_Rogers
    12-12-2012 08:40 AM in reply to: WHassan
    Here is a method that I wrote which replaces an item in a list by index.
    Method ReplaceItemInList(inputList As List, indexOfItemToReplace As Integer, newValue As Any) As List
         Dim lowerList As List = {}
         Dim upperList As List = {}
         If indexOfItemToReplace > 1 Then
              lowerList = subList(inputList, 1, indexOfItemToReplace -1)
         End If
         If indexOfItemToReplace < length(inputList) Then
              upperList = subList(inputList, indexOfItemToReplace + 1, length(inputList))
         End If
         Return lowerlist + {newValue} + upperList
    End Method
    -Chris Rogers
    Inventor Certified Professional
    ________________________________________________________
    If this post helps, please click the "Thumbs up"/"Kudos"
    If this post gives the solution, please click "Accept as Solution"
