- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
I am tyring to edit a mulitilevel/multiDimensional list but I am getting a compile error.
What I am trying to do is;
1. to generate a list of parameters for listed children
2. edit the created list based on a few conditional checks
Now the list is created and is working fine, but when I want to edit an item in the list; I am getting the comlie error.
Here's what my rule looks like:
Rule lstPreStdPanels As List
Dim panelCounter As Integer
'loop to create the panel parameters list
For panelCounter = 1 To intNoStdPanels
lstPreStdPanels = lstPreStdPanels + {{ _
":origin", Point(panelCounter * StdPanelLength,0,0), _
":xDirection", Vector(0, -1, 0), _
":yDirection", Vector(-1, 0, 0), _
":panel_length" , StdPanelLength }}
Next
Dim openingCounter As Integer
'Loop through the opening list to check if need changed length
For openingCounter = 1 To length ( lstOpeningList )
If nth (5, nth( openingCounter , lstOpeningList ) ) = "T" Then
'Determine the target panels
If GetX(Second(nth(panelCounter,lstPreStdPanels)) >50 Then
'nth(8, nth( panelCounter, lstPreStdPanels ) ) = 5
End If
Next' panel counter
EndIf' If opening List = T
Next' openings counter
End Rule
I am getting the error on the commented line.
I could try to place the conditional checks as the list is generated, but I have more that one conditions which are themself in a loop (in contrast to this sample code).
All help is appreciated.
Thanking you,
Wajih
