Autodesk Inventor Engineer-to-Order
- Start Article
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Editing items in a list
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi All,
I am tyring to edit a mulitilevel/multiDimensional list but I am getting a compile error.
What I am trying to do is;
1. to generate a list of parameters for listed children
2. edit the created list based on a few conditional checks
Now the list is created and is working fine, but when I want to edit an item in the list; I am getting the comlie error.
Here's what my rule looks like:
Rule lstPreStdPanels As List
Dim panelCounter As Integer
'loop to create the panel parameters list
For panelCounter = 1 To intNoStdPanels
lstPreStdPanels = lstPreStdPanels + {{ _
rigin", Point(panelCounter * StdPanelLength,0,0), _
":xDirection", Vector(0, -1, 0), _
":yDirection", Vector(-1, 0, 0), _
anel_length" , StdPanelLength }}
Next
Dim openingCounter As Integer
'Loop through the opening list to check if need changed length
For openingCounter = 1 To length ( lstOpeningList )
If nth (5, nth( openingCounter , lstOpeningList ) ) = "T" Then
'Determine the target panels
If GetX(Second(nth(panelCounter,lstPreStdPanels)) >50 Then
'nth(8, nth( panelCounter, lstPreStdPanels ) ) = 5
End If
Next' panel counter
EndIf' If opening List = T
Next' openings counter
End Rule
I am getting the error on the commented line.
I could try to place the conditional checks as the list is generated, but I have more that one conditions which are themself in a loop (in contrast to this sample code).
All help is appreciated.
Thanking you,
Wajih
Re: Editing items in a list
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Editing an element of a list is not possible in the intent language as you have shown. I have worked around this before by creating a replaceItem function which takes a list, an element index, and a newValue and essentially splits the originally list at the index, excluding the item to replace and builds a new list inserting the newValue between the start and end pieces of the two parts of the list.
If this post helps, please click the "thumbs up" to give kudos
If this post answers your question, please click "Accept as Solution"
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you please post/attach the function/snippet.
Trying to accomplish what I had asked has exhausted: I am out ideas.
A fresh perspective would be a re-boot.
Thanking you,
Wajih
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is a method that I wrote which replaces an item in a list by index.
Method ReplaceItemInList(inputList As List, indexOfItemToReplace As Integer, newValue As Any) As List
Dim lowerList As List = {}
Dim upperList As List = {}
If indexOfItemToReplace > 1 Then
lowerList = subList(inputList, 1, indexOfItemToReplace -1)
End If
If indexOfItemToReplace < length(inputList) Then
upperList = subList(inputList, indexOfItemToReplace + 1, length(inputList))
End If
Return lowerlist + {newValue} + upperList
End Method
Inventor Certified Professional
________________________________________________________
If this post helps, please click the "Thumbs up"/"Kudos"
If this post gives the solution, please click "Accept as Solution"
