• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Engineer-to-Order
    Distinguished Contributor
    ludesroc
    ETO Studio 2013 vs Rule Annotations
    67 Views, 1 Replies
    01-29-2013 11:23 AM
    When accessing parameters through the ETO Model Browser in VS...It seams that VS doesn't recognize the rule annotations...
    For example:
    ' Insulation.
    <%%Category("Door Configuration"),_
    %%DisplayName("Door Insulation"),_
    %%Prompt("Door insulation"),_
    %%Choices("Fiberglass|Urethane"),_
    %%EvalChoices("False"),_
    %%ChoicesDelimiter("|") >_
    Parameter Rule DoorInsulationMaterial As String = "Fiberglass"
    The parameter window only shows "Fiberglass"...and not the other choice option for this rule.
    Is there a setting that needs to be configured so VS displays the annotations correctly?
    I'm using Visual Studio 2010 Professional.
    Ludesroc
    Please use plain text.
    Employee
    Re: ETO Studio 2013 vs Rule Annotations
    01-29-2013 12:35 PM in reply to: ludesroc
    This is one of the changes between the "old" Inventor-based IDE and the new ETO Studio IDE.  ETO Studio is meant to be a "developer" interface, not a pseudo-end-user interface.  Hence we changed the behavior of the new "Parameters" dialog, as compared to the old-IDE "Part Editor" dialog.  The new Parameters dialog expects that you, as a developer, will input a formula to specify the value for each parameter ... and hence does not respect the rule-annotations regarding data (non-formula) input.
    I.e., this means you have to input strings with double-quotes, and Names with a leading colon.
    Personally, I think we (that is, "I") took this a step too far with respect to Name-type parameters.  It would have been easy to use the rule-annotations to "suggest" appropriate values, or something like that, and insert it with the leading colon.
    Note that rule-annotations don't go away.  They're just not quite as useful.  ETO Studio respects other annotations, e.g., %%DisplayName for the Model Browser window and %%Category, etc., for the Model Properties window.
    As much as I want people to use ETO Studio, I will point out that the old IDE is still available, just disabled by default.
    Jon Balgley
    Autodesk Inventor ETO team
    Autodesk, Inc.
