• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor Engineer-to-Order
    Valued Contributor
    Change text color through <StyleOverride>
    110 Views, 4 Replies
    02-01-2013 07:57 AM
    How can I change text color using <StyleOverride>?
    Thanks in advance.
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
    Please use plain text.
    Employee
    AlexKorzun
    Re: Change text color through <StyleOverride>
    02-04-2013 07:32 AM in reply to: Lesoux
    You did not mention the type of the Inventor object you wanted to apply the Color to.
    If the object is under Intent control, try the following:
    1. Call GetHostObject()  to step from Intent Part to Inventor object
    2. Use the .Color setter on that object.
    Thank you,
    Alex Korzun
    Principal Engineer
    Valued Contributor
    02-04-2013 07:48 AM in reply to: AlexKorzun
    I'm talking about standard design as :IvGeneralNote.
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
    FarrenYoung
    02-04-2013 09:05 AM in reply to: Lesoux
    I don't believe this is possible via StyleOverride
    Looking at the Inventor API help there is a list of the options that are available via StyleOverride
    mk:@MSITStore:C:\Users\farren.young\Desktop\Inventor%202013%20API.chm::/HTML/FormattedTextTags_Overview.htm
    Style Override <StyleOverride>
    The StyleOverride tag defines all text style information. The various style options are defined within the tag using attributes. These attributes are described below.
    Font – Sets which font to use. The input to this attribute is the name of the font.
    FontSize – Sets the size of the font. The input to this attribute is the size in centimeters.
    Bold – Allows you to turn bolding on or off. The input to this attribute is the String "True" or "False".
    Italic – Allows you to turn italics on or off. The input to this attribute is the String "True" or "False".
    Underline – Allows you to turn underlining on or off. The input to this attribute is the String "True" or "False".
    As Alex mentioned, you will need to override the color property of your object.
    To get the color you have to create it using the inventor application transientobjects class.
    gethostobject(me).set_color(%%inventorapplication.transientobjects.createcolor(0, 255, 0)) 'RGB value
    --Farren
    If this post helps, please click the "thumbs up" to give kudos
    If this post answers your question, please click "Accept as Solution"
    Valued Contributor
    02-04-2013 09:38 AM in reply to: FarrenYoung
    I found best way, I think so.
    Just use Style for Note Text.
    Win7 x64
    Xeon X5647
    24 Gb RAM
    Quadro FX 6000
    Inventor 2013
    ETO 6.1, Build 140.
