• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor Engineer-to-Order
    Accepted Solution
    Add Holes in a Pipe
    225 Views, 1 Replies
    08-10-2012 06:58 AM
    I am trying to add an unknown number of holes at random locations up and down a pipe.  Because of the geometry of the pipe, I cannot simply use the Part Hole Feature.  I'm trying to use the Part Extrude Feature and I'm lost as to how it actually works.
    In the assembly design I have
    Child pipe_1 as :smileytongue:ipe
    End Child
    In the pipe design I have:
    Child Hole As :IvPartExtrudeFeature
        distance = 2
        operation = :cut
        extentDirection = :smileytongue:ositive
        sketchPart = pipe_1
        sketchName = "Sketch7"
        face = "XY Plane"
        origin = "Center Point"
        xAxis = "X Axis"
    End Child
    In the Sketch7 I have a circle drawn in space without any reference lines crossing through the circle.
    I'm getting the error "No such rule 'pipe_1' (parameter) "
    I'm not sure what I'm doing wrong.
    Is there a better way to add the holes to my pipe?
    Andrew
    CAD Drafter
    Please use plain text.
    Re: Add Holes in a Pipe
    08-13-2012 12:25 PM in reply to: alundr
    OK.  sketchPart cannot reference the part I am trying to cut a hole in.  Therefore, I needed to create an .ipt file with a sketch of the profile that I wanted to cut out.   my code now looks like this :
    Child HoleSketch As :HoleSketch
    visible? = False
    End Child
    distance = 10
    operation = :Cut
    sketchPart = HoleSketch_1
    sketchName = "Sketch1"
    face = "XY Plane"
    xAxis = "Y Axis"
    End Child
    good luck
    - Andrew -
