Accessing Inventor Host API from rules
intentdesign
intentdesign
Rule WriteItemNumber As String Dim InventorApplication = Autodesk.Intent.IntentAPI.Instance.HostAPI.HostApplication Dim RootPart = InventorApplication.ActiveDocument 'GetHostObject(root) Dim oBom = RootPart.ComponentDefinition.BOM 'Dim oBOMView = oBom.BOMViews[1] '<---That doesn't work Dim oBOMView = oBom.BOMViews.Item("Structured") '<---That doesn't work too Dim i As Integer = 0 oBOM.StructuredViewEnabled = True oBOM.StructuredViewFirstLevelOnly = False oBOM.PartsOnlyViewEnabled = False For Each oBomRow In oBOMView.BOMRows oBomRow.ItemNumber = "Test" i=i+1 Next Return Format("%d ItemNumbers are changed",i) End Rule
 I try to modify the Inventor BOM ItemNumber from Intent rules via API. The attached code doesn't work.
Is it possible to do it in this way?
Dieter
colin.mccoy
Try
Dim oBOMView = oBom.BOMViews.get_Item("Structured")
intentdesign
Hi Colin
Thank's for your answer. You gave me the answer that let me find the following solution which works fine.
     <%%Category("Positions_Nr")> _
     Rule WriteItemNumber As Any
          Dim Bauteilnummer As String = ""
          Dim oBOMView = oBom.BOMViews.get_Item(2)
          Dim oBOMRows = oBOMView.BOMRows
          Dim iRows As Integer = 0
          For i = 1 To oBOMRows.Count Step 1
                Dim oBOMRow = oBOMRows.get_Item(i)
                Bauteilnummer = oBOMRow.ComponentDefinitions.get_Item(1).Document.PropertySets.get_Item(3).get_Item(2).Value
                oBomRow.ItemNumber = getPosNr(Bauteilnummer,Me.Baugruppe_Pos_Nr)
                Dim oChildRows = oBOMRow.ChildRows
                For j = 1  To oChildRows.Count Step 1
                     Dim oChildRow = oChildRows.get_Item(j)
                     Bauteilnummer = oChildRow.ComponentDefinitions.get_Item(1).Document.PropertySets.get_Item(3).get_Item(2).Value
                     oChildRow.ItemNumber = getPosNr(Bauteilnummer,Me.Stanzteil_Pos_Nr)
                     iRows=iRows+1
                Next
          Next
          Return Format("%d Objekt-Nummern wurden überschrieben!",iRows)
     End Rule
Regards
Dieter
