- Mute
- Permalink
- Report
Rule WriteItemNumber As String Dim InventorApplication = Autodesk.Intent.IntentAPI.Instance.HostAPI.HostApplication Dim RootPart = InventorApplication.ActiveDocument 'GetHostObject(root) Dim oBom = RootPart.ComponentDefinition.BOM 'Dim oBOMView = oBom.BOMViews[1] '<---That doesn't work Dim oBOMView = oBom.BOMViews.Item("Structured") '<---That doesn't work too Dim i As Integer = 0 oBOM.StructuredViewEnabled = True oBOM.StructuredViewFirstLevelOnly = False oBOM.PartsOnlyViewEnabled = False For Each oBomRow In oBOMView.BOMRows oBomRow.ItemNumber = "Test" i=i+1 Next Return Format("%d ItemNumbers are changed",i) End Rule
I try to modify the Inventor BOM ItemNumber from Intent rules via API. The attached code doesn't work.
Is it possible to do it in this way?
Dieter
