vba-imate code for assy
06:43 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The sample vba code in inventor that enables the assy using imate names is for 2 parts which works fine(shown below)but I cannot seem to change it to run for multiple parts due to my vba ignorance!
Does anybody have any similar existing code or help that will assemble mutiple specified parts with respective matching imate names that can be run from a macro?
Example
[Visual Basic] This sample demonstrates creating an iMate result using two existin iMate definitions. To use this sample create a new part by extruding a rectangle to create a cube. Create a mate iMate on one of the faces. This sample assumes the iMate is named the default name used in the English version of Inventor, which is iMate:1. If the iMate definition is created with another name you can either edit the name of the iMate definition in the part file, or edit the sample code below to use the different name. Save the part to C:\Temp\iMatePart.ipt. Finally, have an assembly open and run the sample code.
Public Sub iMateResultCreationSample()
' Get the component definition of the currently open assembly.
' This will fail if an assembly document is not open.
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Create a new matrix object. It will be initialized to an identity matrix.
Dim oMatrix As Matrix
Set oMatrix = ThisApplication.TransientGeometry.CreateMatrix
' Place the first occurrence.
Dim oOcc1 As ComponentOccurrence
Set oOcc1 = oAsmCompDef.Occurrences.Add("C:\Temp\iMatePart.ipt", oMatrix)
' Place the second occurrence, but adjust the matrix slightly so they're
' not right on top of each other.
oMatrix.Cell(1, 4) = 10
Dim oOcc2 As ComponentOccurrence
Set oOcc2 = oAsmCompDef.Occurrences.Add("C:\Temp\iMatePart.ipt", oMatrix)
' Look through the iMateDefinitions defined for the first occurrence
' and find the one named "iMate:1". This loop demonstrates using the
' Count and Item properties of the iMateDefinitions object.
Dim i As Long
Dim oiMateDef1 As iMateDefinition
For i = 1 To oOcc1.iMateDefinitions.Count
If oOcc1.iMateDefinitions.Item(i).Name = "iMate:1" Then
Set oiMateDef1 = oOcc1.iMateDefinitions.Item(i)
Exit For
End If
Next
If oiMateDef1 Is Nothing Then
MsgBox "An iMate definition named ""iMate:1"" does not exist in " & oOcc1.Name
Exit Sub
End If
' Look through the iMateDefinitions defined for the second occurrence
' For Each method of iterating through a collection.
Dim oiMateDef2 As iMateDefinition
Dim bFoundDefinition As Boolean
For Each oiMateDef2 In oOcc2.iMateDefinitions
If oiMateDef2.Name = "iMate:1" Then
bFoundDefinition = True
Exit For
End If
Next
If Not bFoundDefinition Then
MsgBox "An iMate definition named ""iMate:1"" does not exist in " & oOcc2.Name
Exit Sub
End If
' Create an iMate result using the two definitions.
Dim oiMateResult As iMateResult
Set oiMateResult = oAsmCompDef.iMateResults.AddByTwoiMates(oiMateDef1, oiMateDef2)
End Sub
Example
Dim i As Long
Exit For
End If
Next
Exit Sub
End If
Exit For
End If
Next
Exit Sub
End If
End Sub
