using iLogic to automatically change Title Block size based on Border size
Greatwhitenorth
Greatwhitenorth
Hi all,
I'm trying to create a rule that will change the Title Block size based on what Border size the user changes to.  The default drawing template is a B size, but if the user was to change it to a D size, the Title Block is too small.
This is what I have done so far:
If ActiveSheet.Size Is "A" Then
ActiveSheet.TitleBlock = "TitleBlock Small"
ElseIf ActiveSheet.Size Is "B" Then
ElseIf ActiveSheet.Size Is "C" Then
ActiveSheet.TitleBlock = "TitleBlock Large"
ElseIf ActiveSheet.Size Is "D" Then
End If
I works, but only if the user manually runs the rule.  Is there a way to have it automatically run when the Border changes?
Thanks in advance.
Bob
__________________________________________________________
Product Design & Manufacturing Collection 2025 | Vault Professional 2025
Dell Precision 7670 | Intel i7-12850HX - 2100 Mhz - 64GB
nVIDIA RTX A3000 12GB | Windows 11 Pro
Curtis_W
HI bstewart,
This link from Jonathan Landeros' blog might help:
http://inventor-tales.blogspot.com/2010/11/drawing-conclusions-on-formatting.html
and this one might be of interest as well:
http://inventortrenches.blogspot.com/2011/05/use-ilogic-to-change-sheet-orientation.html
I hope this helps.
Curtis
MjDeck
Bob,
Unfortunately, there's no way to run the rule when the border changes.  There's only a few drawing events available.  I would recommend running the rule on the Before Save Document event.  You can attach the rule to this event by using the Event Triggers command on the iLogic tab:
Mike Deck
Software Developer
Autodesk, Inc.
Greatwhitenorth
Thanks Curtis.  I used Jonathan's sample code to create mine.  Works like a charm!
Bob
